Can’t publish my RW site on FatCow
(I’m trying to replace a site I created with iWeb ( http://www.rossmoorcameraclub.com/RossmoorCameraClub/HOME_1.html ) with one I have created using RW.
Attempts to publish my RW site using FatCow http://www.fatcow.com/knowledgebase/beta/article.bml?ArticleID=1724 fail. It appears to go through of the process of downloading all 95 files and they appears to be on Fatcow but it does not update the site… Even though I get a RW message “Publishing Complete The changes to you web site have been published. I have tried this several times.”
I have talked with FatCow customer service and after about 50 minutes of changing publishing setting with no results they said I would have to contact Rapid Weaver.
FatCow does has a help page http://www.fatcow.com/knowledgebase/beta/article.bml?ArticleID=1724 saying Quote: Offline website builders usually require you to enter your FTP setting once. Here are a few offline website builders you might consider. Use these along with our generic settings to publish your site End Quote. Followed by links to sever hosts, clicking on Rapid Weaver returns the message: Safari Can’t Find Server Safari can’t open the page.”help.realmacsoftware.com/hc/en-us/articles/200167091-Publish-your-website. because safari can’t find the server “help realmacsoftware.com.
The setting I have used are:
Publishing Method: FTP
Server: cllmd.fatcow.com
Connections: 6 Lighting fast
Username: LWCLL
Password: {may password}
Path:/rapidweaver
Mode: Extended Passive
I am running:
RapidWeaver 7.1.7
iMac 27 inch with macOS Sierra v 10.12.2
