I’ve implemented Impact.It’s great – except, the foreground stacks disappear after a second or two. Can I prevent this? Thanks
It’s always easier to help if we can see the issue that you are referring to.
Thanks Joe, please go to https://beatricehamblett.com
The issue is on the first page.
I have the stack set up as follows:
tickle
Set Target to relative to parent. You have it set relative to browser which will end up behind Impact.
like so:
https://bwd.d.pr/lmlSyV
Thanks @Tav. I now have my project configured with the same Target settings as yours. I still get the logo appearing and disappearing… Watch the home page for 15 secs. to see what I mean
Oh, and thanks very much for responding.
You do not appear to have Target dropped into the Impact “Foreground: Floating” dropzpne.
You must ensure that it is dropped directly into this dropzone. If you cut the Target from my example project, you will see the dropzone that it is in:
That’s it! Thanks a ton. David
