Or, you look here! Open “Go to” window in the menu, press the alt/option button, then the library will appear between User and Computer.
Then you must click the whole path.
For me this path.
/Users/schmid/Library/Containers/com.realmacsoftware.rapidweaver6/Data/Library/Application Support/RapidWeaver
1 - I found my theme Simple-BvA01.rwtheme in RW6 Themes
2 - In Apple OS X I found my Library with alt/option button and was able to find the theme Simple-BvA01.rwtheme in
/Users/your name/Library/Containers/com.realmacsoftware.rapidweaver6/Data/Library/Application Support/RapidWeaver
3 - However I have not been able to find Reveal Add-on in Finder in RW. I simply don’t get that menu.
4 - are their other RW files in the Library?
I use 2 computers so if I move from one computer to the other which files should I copy?
@neuron
Read here, Perhaps it helps. It’s a very complicated thing.
I would prefer to install RapidWeaver on the second computer, and then to reinstall all themes and plugins on the new location.
That gives a lot of work, but everything is correct.
Or…
This is the somewhat simpler way.
When you copy this file/that folder you should have all important things on the new computer. com.realmacsoftware.rapidweaver6
