Hello! - I´ve tried to insert this html code with the embedded “HTML-Stack” from rapidweaver but the content isn´t displayed correct… maybe someone can help me…
Here´s the code:
Here´s the code:
To include code you need to select the symbol with angle brackets enclosing a forward slash. My bet is you need to highlight the code and selecr ‘ignore formatting’.
You need to mark code in your posts or it doesn’t show.
Select the code and use the </> to mark.
