I use this stack which works fine but I can not change the background colour of different calendars! I have tried all permutations I can find, it simply ignores them, any advice? Thanks.
A URL might help.
https://www.energyinyoga.com/findoutmore/events/index.html
18//8/20 has an entry to 2 events, they are in different calendars, but i cannot differentiate them by color?
I don’t have kalendar, but looking at the HTML that it generates, I can’t find anything that would indicate which calendar the entry is coming from.
I was hoping there might have been an attribute that we could apply some CSS too.
Thanks, I will try to experiment, hopefully someone from kalendar will respond!
Fixed thanks all. I simply deleted the stack and re inserted it and it worked fine!
