Keeps asking for licence
Every time I start Rapidweaver 8 it asks for my licence code. This has only started happening since the beginning of 2019
Hi Paul!
Sorry to hear about this.
There’s a few reasons why this could be happening, but here are the top few:
  • You have a network/software firewall that blocks incoming/outcoming connections (ex: LittleSnitch)
  • An app like CleanMyMac, MacKeeper (etc) is installed that deletes files RapidWeaver uses to store registrations
  • Permissions issue and RapidWeaver doesn’t have sufficient privileges to read/write to your preference file
Can you do a run through and see if any of those are more likely in your case?
Thanks Aaron,
It turns out to have been a pesky disk cleaner app!
All sorted now.
Thanks again,
Paul
Glad to hear that’s been resolved! :slight_smile:
Aaron or Paul, could you please provide more information? I have been using Clean my Mac for some time, but just this past week, RW has lost my registrations for a bunch of plugins - PlusKit, SiteMap, Weaver Pix, etc. (but not RW itself).
I have quit Clean my Mac but of course these registrations are still missing - could you please explain the steps to restore these files? Can I find them on Time Machine?
Thanks,
Bonnie
I don’t believe there’s a way to restore licenses from time machine. You will need to re-enter the keys from each plugin.
Stop using Clean my Mac - It breaks more than it fixes
Thanks for this information. Fortunately the issue seems to be limited to only 3 or 4 plugins.
It’s doing it again!
For the past few days Rapidweaver has been asking for the licence code every time I start it up. In this time I have not used any disk cleaning software.
After a few days of stability, it did it again today. :roll_eyes:
8.1.5 still asks for the licence code every time I start it up.
Updating to 8.1.6 hasn’t fixed this either!
Sounds like something is deleting files needed by RapidWeaver.
Since no other folks are reporting the same problem, I would assume it’s something unique to your setup.
Are you running RapidWeaver from the applications folder?
Are other plugins like sitemap plus or stacks asking for a license as well?
Perhaps someone from realmac could jump in. @dan @Aaron?
Hi Aaron,
The only security software running is Bitmedic Pro. This has a ‘whitelist’ facility that would allow my drag and drop any file or folders not to be scanned. Please let me know the name and location of any Rapidweaver files that I should preserve.
Best regards,
Paul
[email protected]
07971 820 990
Hello Again Aaron,
I’ve just noticed that Rapidweaver 7 was still in my Applications folder. Could this have been causing it? I’ve trashed it now anyway.
Best regards,
Paul
[email protected]
07971 820 990
