Solved: RapidWeaver 8 always wants to be activated
Hi there,
I just upgraded to RW 8 under macOS Mojave.
Every time I start the app, it wants to activate the license again and again.
Once activated, it runs normally, but if I quit the app, it does not remember the license data on the next start.
I read about the same issue with RW7 in the forum here.
Is there meanwhile a solution for this issue ?
Thank you very much,
Harald
Some additional information:
  • RW is running on an iMac with Ethernet enabled and WiFi disabled
  • Disabling Little Snitch had no effect.
  • Cleaning the installation with AppCleaner and reinstalling RW had no effect.
– Harald
Did you see this post?
Would bet it’s a firewall (like little snitch) issue.
You won the bet :slight_smile: Thank you very much, for the hint.
Here the solution:
  • Little Snitch was running in “Silent Mode”.
  • I disabled Little Snitch without any effect.
  • Then I enabled it and switched to “Warn Mode”
After this the license was recognized immediately.
Looks like a bug in Little Snitch …
– Harald
