Lost RW installation, forgetting some stacks, trying to recover them
My hdd & time machine both bit the dust. I’m back up and running but having to rebuild my RW installation & project from scratch, so that I can edit my already established RW project that I had saved in the cloud. Is there a way to see what stacks a site is using through looking at it’s source code in the browser or within the exported files?
If you’re running the latest Stacks plugin and you open your project it’ll show you the missing stacks and their names.
What I’d do:
  • Open the project
  • Note any missing stacks
  • Close the project WITHOUT SAVING IT
  • Close RW
  • Install the missing stacks
  • Repeat
Remember to look in Partials and any collapsed/hidden stacks you may have for missing stacks.
