I’ve got the settings for H2 family styles and it’s showing my paragraph text styles. @tav what am I doing wrong?
Or is it just because the size is set so small?
Nope. Have different fonts for header and text. Header is 700. Should be thick.
Make sure the font family is set in the marker stack Generated Menu Items
settings as well.
Each marker can override the font used for links.
They can be set to inherit the bar setting or to a specific font of their own. Either the same setting as the bar or Inherit
will work.
That was it, thank you
