Menu bars not showing on iphone
I am using Top Bar (foundation) for my menus and when I reduce to iphone size I don’t see the menu or even the little lines to pull down a menu. Any help would be appreciated. Thank you
Website is https://www.drsarahshell.com
![Screen Shot 2021-05-21 at 12.56.19 PM|690x254]
I don’t know if this is causing the issue, but I noticed you are mixing frameworks. You have Foundry and Foundation stacks being used.
Frameworks can’t be mixed.
  • If you are going to use Foundation, then you can’t use foundry stacks.
  • If you are using Foundry, you can’t use Foundation stacks.
  • When you use Foundry, you need to have the theme set to Foundry.
  • When you use Foundation, you need to have the theme set to Foundation.
  • When you use Foundry, you need to have the Foundry Control center on each page.
  • When you use Foundation, you need to have a site style stack on each page.
  • You can usually use NON-Framework stacks with either Foundry or Foundation
Thank you that helped solve my issue, I switched all to foundation. Appreciated :slight_smile:
