Hello
Tried to get stackslider working in the popdrop stack and it doesn’t work.
Has anybody tried this with the “moving box” stack?
thanks for your comments
Hans
Hello
Hans
Most if not all slider stacks will not work correctly inside something that hides the slider on page load. This is because when the page loads the stack, it is looking to create a height for the slider. Since it is hidden, the stack gets a height of 0, making it not show correctly when finally revealed. That being said, PopDrop and MovingBox work together better than any others I have seen. Still, not something I would use on my site, but you can see my test of it here:
http://www.zeebedesigns.com/popup-movingbox/
Thanks Robert for the showcase; that really helps
regards Hans
