Moving to fttps from fttp
Just wondering if the file path will change when uploading my site going from fttp to fttps or do I just change the filed “Webside Address” in ‘Publish Settings’ by adding a “S” to my url?
I don’t know if this is an obvious question I just want to be 100% sure.
Yes @Dreadas
In the General Site Settings in RW add the https:// in here:
But adding an SSL to your domain shouldn’t affect your site where this is a necessity. If you add a little snippet to your htaccess you should be good to go:
That’s an expert from my better weaving free course:
http://email.yuzoolmail.com/h/r/4489C84BB619C04F
Hope you get setup ok :slight_smile:
That was really well explained and the text about htaccess makes things really simple to understand :hugs:
EDIT Here’s the command as text for anyone who needs it:
RewriteEngine On
RewriteCond %{SERVER_PORT} 80
RewriteRule ^(.*)$ https://yourdomainname.com/$1 [R,L]
