I notice these warnings appear in Rapidweaver on sites still using Foundation 1. Foundation is selected as the theme. What does it indicate? The link leads nowhere.
Foundation 1 should still work.
Make sure you are using the latest Foundation 1 theme, not the F6 theme.
Also make sure you have updated the stacks(update button) at the bottom of the stacks library.
You should be fine as long as you update your Foundation 1 theme. I’m still using Foundation 1 for sites that I haven’t yet converted to Foundation 6.
Thanks!
Great. Thanks. The red alert warning seemed ominous!
