Navigation Menu
Hi there, at current release(22852). I found that there is no Navigation Menu component or similar thing for me to build the Navigation Menu or Hamburger Menu. Is there a chance to add this component in next release?
Thanks.
its down near the bottom but its just basic at the moment
@Godber Thanks for your reply!
Now I can add menu, but I can’t edit or delete the text ‘My Website’
think its general settings…cog wheel next to publish tab
leave blank or edit
@Godber got it. Thanks.
Navigation Menu is essential for webpage design, I hope we can use this as a core component soon.
are you new to this??? you honestly think they would create a web design page and not include a menu system??? just turn the one your creating into a global!!
No reason to be mean. These were honest questions.
not being mean…where was I mean…question 1 are you new to this? do you think they wouldn’t have a menu system?? then turn it to a global…more help…so still looking for the mean bit?
if the roles were reversed I would have said yes/no im not new
good point about the menu question
and thanks for telling me about globals???
I think that some things could use a little consistency. In a wisiwig environment, you should be able to change something like that on the page and not have to look for a setting…somewhere.
you will be able to. It’s just a basic one to get people going. I dont like drop down menus personally but at the mo theres no way to hide pages but ive been told its coming.
