Hi, is it possible to transfer a website designed and uploaded in iWeb to RW?
Michael
Michael
Sadly not! You can easily copy the text and images into a new site of course. If you have the url of your site I could estimate how difficult it would be.
Jonathan Hi,
thanks for the fast response.
The url is
http://volgaeditingservices.ru/Volga_Language_Services/Welcome.html
It looks like I will have to do the manual transfer through RW.
Michael
Your site is very simple in construction so wouldn’t take long at all to transfer the text and images.
If you just want a similar site there are the built in themes that come with Rapidweaver or you can buy add-on themes that have more options and have a bit more eye candy. Rapidweaver also has a built in blog which you can use with any theme. It all depends on what you want your website to develop into.
Jonathan Hi,
thanks for that, much appreciated.
Michael
