DaveFox
(Dave Farrants)
21 August 2015 09:47
1
Nothing will publish, using Version 6.3.2 (15039), worked OK with previous version, publishing just shoots the blue bar to the right and says Visit website or Done but no changes to site - any ideas?
nikf
(Nik Fletcher)
21 August 2015 09:57
2
Please re-download a newer build
Hi guys!
RapidWeaver 6.3.2 launches next week: we’ve got a GM build ready, we’re just getting a few things in place behind the scenes for the update.
An update to Blocks (from YourHead) to improve compatibility with the changes in RapidWeaver 6.3.2 will be launching alongside this update. Here’s what’s new in RW 6.3.2:
New Features
RapidWeaver now supports “Active” FTP uploads. Active FTP should only be enabled if your host requires it - if that means you, enable it via the Cog menu in the p…
There was a bug in the initial GM which has since been corrected.
—N
