Opening my old websites
I have 2 websites I have not updated in quite sometime because I could not open my old MacBook. I have purchased a new MacBook and downloaded the updated rapid weaver software. I bo not want to make new websites I wish to open my old ones and update them. any help? thank you
How old?
I have opened RW5 & RW6 & RW7 in RW8…not many issues.
Ancient! Must be 2005. I have the websites but need to update them. Is there a way to import my websites into the new updatd software?
Unless you have the original project files and can go through the various versions of Rapidweaver then I bet it will be easier to copy the text and images into a new project. You said you were going to update it anyway.
This post might be helpful:
https://help.realmacsoftware.com/rapidweaver-7/upgrading-from-rapidweaver-5-or-6
No. You can’t go to your website and ‘suck’ its contents into Rapidweaver. You’ll need the original project files and then I’d refer you to @thang’s post.
