Padding issue on Armadillo blog
I’m playing with Foundation and Armadillo and have managed to get the blog working in a way that I’m reasonably happy with https://www.thepunctuationshow.com/test/blog/
For some reason, whatever adjustments I make to the margins and padding in Rapidweaver, it doesn’t seem to alter anything. This is regardless of whether I change the padding in the Foundation stacks or the Armadillo stacks.
Is there anything silly I’ve missed as that’s usually the case?
Can you explain what you want and what it’s actually doing?
Hi Joe and thanks so much for the reply. I just want more white space in between the banner and the heading and then more white space between the header and the blog stuff, but no matter which stack I seem to add padding and margin to, it doesn’t seem to add any.
It seems to be a publishing issue - think I’m sorted though thanks.
