Page Inspector too wide
Hello,
Is there a way to make the Page Inspector not so wide on my screen? I tried grabbing an edge and resizing it, but that doesn’t seem to work. When it’s open, it takes up too much of my work area, and I usually like to work with it open. Thanks!
@cynthia
If you have RapidWeaver 6 and Stacks 3…
Add or edit a stacks page
Go to the NUT icon
At the bottom left there is a selection of use pop-over or window, choose either that suits (probably Window)
HTH
Brad
A funny thing, I couldn’t find a NUT icon anywhere, then I figured you must be talking about that thing on the top right. I was looking all over for an acorn or something. I guess it’s another difference between the perceptions of men and women. :slight_smile: Anyway, when I do what you said, it does let me move it, but I still can’t make it skinnier. Is there a way to make it not so wide? Thanks!
@cynthia
Mars and Venus… remember? lol
No way to make it skinnier, however, now you can place it where you want… I assume you’re using an 11/13 or 15" screen?
You could try using a higher resolution at the expense of possibly needing a magnifying glass…
you could also set Stacks to be a pop-over, that way it is only active when you are wanting to find and use a stack on your page…
Brad
Yes, I do remember Mars and Venus, and you’re right! :slight_smile:
And yes, I’m using a 15" MacBook Pro. I just got a new one, and I really like it.
Too bad it doesn’t get skinnier; and I think I’ll have to pass on the magnifying glass, so I guess I’ll just have to leave it fat. Thank you so much!
