I’ve tried changing every Inspector parameter which might be relevant. But on this test page of mine, I cannot get my images to align in a grid; and the third image (magenta leaves) is larger than the first two.
Do I have to pre-size all images to conform to specific dimensions; if so, which?
I have - BTW - followed the video tutorials; they suggest it all almost takes care of itself.
Shouldn’t the Stack automatically put them in a grid?
I bet it’s something really simple that I’m missing!
I think/thought - though I could be wrong - that I was doing:
• I’m adding a Photo Group,
• populating it by dragging resized images to the well in the Inspector of Photo Single
• I then make the images all invisible except for one
• at the top of my Stack - just below the Photo Base, I have ‘one last’ (to quote from Nick’s video tutorial) Photo Group which has these settings:
My understanding from the video tutorial (‘Gallery Collections’) that is accessible in Stacks > Photo > Manual from this page is that the ‘one more Photo Group’ that you need to create (at the top) has to be ‘Target’… that’s what Nick seems to be saying at about 40 - 43 seconds into that video.
I changed that top Photo Group to ‘Normal’ and this is what I get:
What do I now drag into that Group? I thought that the purpose of that Group - whose type was Target - is to act as a menu with one chosen example image from each other Gallery. Click on that thumbnail and it takes you to the relevant Gallery.
I read this treat because I want to know if photo stack 1.3 works under RW 7.x ?
Is that problem in this treat a bug or only a Individually occurring problem ?
Thanks for you help.
Or I forgot can someone tell me sites where the photos stacks use ?
Nick was good enough to send me a zip file yesterday of a RW project with a fully functioning Photo Stack. I’m also on 7.4.1 and it worked perfectly - so I suspect you’ll be OK.
But, as you can see from this thread, I cannot get thumbnails to display as they should in the projects I create. I was beginning to suspect the Theme I was using. So I change the project above to Nick’s own Reason: same result.
Nick is an excellent developer. The difficulty I’m having shouldn’t affect you with the combination of versions that you have. Good luck!
Nick has just written back to me too - and on a Sunday (!) explaining where I was going wrong. It’s necessary to make one thumbnail in the ‘original’ galleries’ Linked - not those in the menu gallery. So… Solved
