PHP version problems
My Rapidweaver website is apparently using PHP 5.3, but when I go on my hosting web control panel, it says I am running version 5.6.
Is there something within Rapidweaver that I can change to get these two to reconcile- its currently causing my shopping cart to not work …I think.
You should upgrade to PHP 7.2 or higher on your server. If you host does not support that, then I think that its time to find a new host.
Hi Joe…thank you for your reply…I did do just that and my RapidCart page couldn’t be found by the server! I.m at my wits end with this!
I am not sure what could not be found. You will need to provide more details.
