Why won’t these upgrade?
Rapid search pro is no longer available, the ”plugin” version has been supported for several years. The stacks version that replaced the plugin has also been retired.
I’m not familiar with mobilizer, so Im guessing it’s quite old as well.
The Ecwid store plugin is still available and the latest version should be notarized and function fine.
You upgraded your macOS to Catalina or Big Sur I’m betting. You can thank Apple for these issues. Since Catalina, they now require even plugins that have been on your Mac for years to be notarized. Protecting you from yourself is their excuse, every release it’s locked down even more.
Yep. Upgraded to Catalina. Thanks for helping me out.
