PlusKit 3.0 -- Now from YourHead
This is a free update for existing users. With lots of bug fixes and improvements for RapidWeaver 7.
Go grab it and enjoy.
About the release: http://blog.yourhead.com/pluskit-v3-0/
More PlusKit Info: http://yourhead.com/pluskit
Download: http://yourhead.com/pluskit/download/
Congrats on the release @isaiah and team!
Awesome news @isaiah, congratulations and thank you for the continued maintenance and advancement of LogHounds originally designed stacks!
Can’t wait to see what else pops up with the others…
Brad
Congratulations and thank you for giving PlusKit a new life.
Thanks @isaiah. It’s one of my favorite plugins.
Henk
Hi Isaiah,
I have PlusKit 2.92.2 installed right now (RW 6.3.8) on OS X 10.11.2.
What is the process to install the update? Do I need to uninstall the PlusKit I have now first and then install PlusKit 3.0? Will the same registration code work?
Thanks in advance,
Slavi
Fantastic - thanks so much for all your hard work on this great utility
Thanks, it’s the plugin I prefer!
@Slavi Usually it’s pretty simple:
  1. Download.
  2. Double click to install.
There are two potential complications:
  1. If you have multiple versions of RW installed, drag and drop the plugin onto the icon.
  2. If the installation doesn’t go as planned for any reason (error message, etc.) then remove the old one first and try again.
Isaiah
I don’t think it’s a problem, but it’s still showing up as a Loghound plug in rather than a Yourhead plug in. Is this normal?
@bazza
No, it is not normal, I had the demo of Loghound installed and upgraded to Yourhead without issue
What version of RW (Requires RW6)?
Uninstall the plugin, restart RW
Go to Yourhead’s website, download the V3 of PlusKit
Install the plugin, restart RW
Add plugin to page, insert your serial number
It should show up in Manage Addons as YourHead
Brad
I create a new project to test the new PlusKit 3.
It has only two pages: one text stack page (page 1), and PlusKit (page 2).
PlusKit recognizes without problems my Loghound registration, but when I go to preview the PlusKit page starts flashing and exported itself in a kind of loop.
RW 6.3.8. El Capitan 10.11.4
Any idea?
Best
Thanks Isaiah,
So far so good!
Slavi
The Page only enables the functions of Pluskit, like @import etc. But Loop is her too, but only on Preview ( what you don’t need)
@peppermint
PlusKit page is not to be previewed, this is an issue with RW 6.x and PlusKit 3.x, just go back to edit mode if you accidentally preview the PlusKit Activator Page
It should automatically remove itself from the navigation menu by de-selecting “Show in Navigation” in Inspector. If it has not then please do so as the page has no visible effect on your site, it only enables the PlusKit features.
Brad
@turtle - must have been a glitch as it’s mysteriously popped back into place! Thanks though.
Hi Turtle,
Of course, I know that PlusKit is not to be previewed and should not be displayed in the navigation menu, but I do preview accidentally and caught my attention this behavior.
Best
@peppermint - no. not normal. please send the simplest file that behaves this way to our support folks (support@yourhead.com) for assistance. i’d like to have a look at that file.
Sent bug report @isaiah with sample project.
Brad
ahhh… i see now… only happens in RW6. :wink:
I’ll see what I can do about that. Until then, try to get into that private beta of the [redacted] thing. :sunglasses:
