I’ve been happily updating my very simple website 3-4 times/year.
Currently on RW 9.2.1, publishing to Ionos.
Today I got a message to the effect “PlusKit plugin is missing. Pages using Pluskit will not be published.”
I know it is no longer functional for Elements, but I’m not using Elements,
and did not delete my (functional) Pluskit plugin. Where did it go?
This will bring up a Finder window, displaying the contents of a folder. Pluskit should be there, either as a sub folder or as a .rapidweaverplugin file. I don’t have it installed, so it doesn’t show up on the screenshot below, but it should on your Mac:
If Pluskit isn’t there, then RapidWeaver is right: the plugin is gone. You can check if RapidWeaver moved it to the “Plugins Disabled” subfolder (and move it back to the main folder if it has). RapidWeaver does that if you deselect the plugin from the app settings.
If you can’t find it there either, then it must have been removed by some other process. You should be able to redownload it from Yourhead’s website and reinstall it.
If Pluskit is there, then drag it out from the plugins folder to your desktop and close RapidWeaver. Then, with RapidWeaver closed, double click on the plugin (on your desktop) to bring up the Plugin Installer window. Move through the steps to register the plugin (it will automatically be moved back into the plugins folder, no worries).
