Can you add previous post and recent post buttons at the bottom of visible posts to a Rapdiweaver Blog page as you would see in Wordpress and Blogger?. If not is there anyway of adapting the blog page to achieve this?
I don’t believe that functionality is built into the RW Blog Plugin Page. I think that this has been a feature request, and that the blog page could use some love.
If you’re looking for a solution right now, I’ve used RW/Writer in the past and been very pleased. The $2/mo is a great value. Only issue is getting your blog in the system to begin with… can be a problem if you have a bunch of posts. That’s going to be a problem any time you change platforms though.
