Read more... button in RW blog
Hi, I am using RW Version 8.1.7 and I’m using Foundry on a Mac and have published my website www.imlistening.ca. I have added a blog page but it appears that once I click on the Read more… button under a blog image and I read the story, I can’t get to the next blog entry or back to the main list of blogs without leaving the blog page. Everything else seems to be working fine. Does anyone have any suggestions for me? Perhaps a setting that I have missed?
Thank you in advance. Most appreciated!!
Lydia
Hi Lydia,
I don’t think you will succeed with the default blog plugin inside Foundry. Foundry is relying on stacks, and the default blog plugin doesn’t allow stacks to be used.
If you are interested, check out Poster Stack, which allows what you are searching for.
There’s also a specific Foundry-friendly blog called Alloy which is sold by the same developer as FFoundry.
Rob
Thanks Jannis, I’ll check it out. This is helpful.
Lydia
Hi Rob I will go check Alloy out. Much appreciated!!
Lydia
Poster stack worked for me thanks for the suggestion!
Lydia
