Problem with Sitemap plus, cannot export, is there an alternative?
Sitemap plus does not work anymore, here is what happens:
NSInvalidArgumentException
-[RWSiteLayout pathToPage:fromPage:inDocument:relative:]: unrecognized selector sent to instance 0x6040002051a0 We suspect this is caused by a plugin, please notify the developer of this problem.
SiteMap Plus (3.1.0b1) from YourHead Software
0 CoreFoundation 0x00007fff44b9668b __exceptionPreprocess + 171
1 libobjc.A.dylib 0x00007fff6be23c76 objc_exception_throw + 48
2 CoreFoundation 0x00007fff44c2f1e4 -[NSObject(NSObject) doesNotRecognizeSelector:] + 132
3 CoreFoundation 0x00007fff44b0cb50 forwarding + 1456
4 CoreFoundation 0x00007fff44b0c518 _CF_forwarding_prep_0 + 120
5 SiteMap 0x000000010fd8f88e -[LHPage pathToPage:fromUniqueID:] + 382
6 SiteMap 0x000000010fd915bc -[LHPage(HTMLTreeView) childViewPrivate:showDescription:usedSet:] + 364
7 SiteMap 0x000000010fd913fc -[LHPage(HTMLTreeView) childView:showDescription:usedSet:] + 108
8 SiteMap 0x000000010fd866ee -[RWSiteMapPlugin contentHTML:] + 1918
9 RWKit 0x0000000109120dd9 -[RWExporter pageContents:params:] + 622
10 RWKit 0x000000010910c0f8 -[RWExporter _exportPage:subPagePath:toPath:inRoot:usingName:] + 5648
11 RWKit 0x000000010911e886 -[RWExporter _exportPage:subPagePath:toPath:inRoot:usingName:includingChildren:] + 279
12 RWKit 0x000000010911f9c7 __45-[RWExporter _exportPages:toPath:completion:]_block_invoke + 90
13 Foundation 0x00007fff46c2952f NSBLOCKOPERATION_IS_CALLING_OUT_TO_A_BLOCK + 7
14 Foundation 0x00007fff46c29391 -[NSBlockOperation main] + 68
15 Foundation 0x00007fff46c2783e -[__NSOperationInternal _start:] + 778
16 Foundation 0x00007fff46c23867 __NSOQSchedule_f + 369
17 libdispatch.dylib 0x00007fff6ca03db8 _dispatch_client_callout + 8
18 libdispatch.dylib 0x00007fff6ca16e81 _dispatch_continuation_pop + 472
19 libdispatch.dylib 0x00007fff6ca0e733 _dispatch_async_redirect_invoke + 703
20 libdispatch.dylib 0x00007fff6ca059a9 _dispatch_root_queue_drain + 515
21 libdispatch.dylib 0x00007fff6ca05755 _dispatch_worker_thread3 + 101
22 libsystem_pthread.dylib 0x00007fff6cd55169 _pthread_wqthread + 1387
23 libsystem_pthread.dylib 0x00007fff6cd54be9 start_wqthread + 13
Is there a fix or an alternative?
PJ
This is a known issue.
The current version is 3.1.0. Install the latest version and you should be OK.
http://yourhead.com/sitemap
Having said that, there might be an issue with Sitemap Plus and the latest RW beta. RapidWeaver 8.2 Public Beta 1 (20697b) — UPDATED BUILD
I have the latest version with I reinstalled anyway, in order to export and publish I have enable Rapidweaver sitemap and disabled sitemap plus in preference, but I am not entirely sure what bitmap from RapidWeaver is able too do
PJ
What’s bitmap?
I’ve just added Sitemap Plus to one of my test RW8 projects and it published ok.
sorry, misspelling, (probably autocorrect?) sitemap from RapidWeaver
The built in sitemap function that you select in advanced settings will build the sitemap.xml file used by most search engines like google. The sitemap it builds contains the pages that are included in navigation.
I am very happy with a .xmlsitemap, but this does not solve my problem with sitemap plus; this is a very good stack, but if it does not work anymore is there something to replace it?
may be Isaac can help with this one
PJ
@isaiah is aware of the issues with the current versions of Sitemap. He is working with Realmac to get a fix out as soon a possible.
I think the latest non-beta version of stemapPlus works with the latest non-beta version of RapidWeaver.
Are you running the beta version of RapidWeaver?
If so you may want to back up to the last production version of RapidWeaver (8.1.7) and try that with the latest production of sitemap Plus.
yep, I checked in the preferences, and beta updates was ticked, so my version of RapidWeaver is Version 8.2 (20703b) I hope the crash info I copied on this thread is some help for Isaac, and we get an update soon; sitemap plus us such a useful stack, I hope it is updated and keep on going
i posted some details and some new versions over here in this thread: RapidWeaver 8.2 Public Beta 1 (20697b) — UPDATED BUILD
i’ll try to finalize the release versions to the general public before the beta testing is done. at the time of this post RW 8.2 is in beta 3 – but beta 3 has some issues with plugins currently. i will probably wait until those are resolved before finalizing these changes.
however – if you’re using 8.2 at all, i think these beta versions of SiteMap and PlusKit should work fine. :slight_smile:
Isaiah
Update: I released Sitemap v3.1.1 PlusKit v4.1.5 – both should auto-update if you are running a recent version. If you have trouble with the update, you can always just go to http://yourhead.com and download the latest version by clicking the Download button and install in the regular way.
If you have any other issues, please feel free to contact our support line – http://yourhead.com/support
Christi has been doing tech support for Mac software since 1995 and is very patient at helping people with tough problems. :slight_smile:
