Problems Saving my RW file
That could be it. I see the option to message you…
And now it won’t even open the file… unbelievable.
Can you make a copy of the file in the Finder?
Do all copy/original/backup have the same file-size (in the Get Info window):
Can you post the last section of the Get Info window. It should look something like this:
Ok, so I did a literal “copy & paste” of the file to a higher directory and it appeared to copy fine. 55.4mb each. BUT, it came from an older file that is 86.4mb… meaning the file lost 30mb somewhere along the way. I have also been struggling with losing images after I drag and drop them in a lightbox. I’ll save and reopen later and all the files (jpgs) i’ve dropped in are missing again. This started happening 4 or 5 months ago. Any chance the overall file size is an issue?
46%20PM
Uh oh… this just happened. I just upgraded… forgot to move it. I’ll fix this and see if that’s the issue (although this was happening with RW7 before I upgraded)
14%20PM
Ok, it appears to be working at the moment…now that I’m running off the program from the apps folder. It saved ok the first try. I’m going to keep working…
