Hi there. Publishing problems for boreal theme rapid weaver. It may not be in my publishing settings as I checked them with Web HostingNZ (my host). I tried changing theme as well but no go.
Appears publishing settings ok. But published site lacks any formatting
Probably an easy fix here …covered off before most likely…maybe someone can give me an easy pointer?
Excuse my ignorance…
Thank you
(I can’t put in a screen shot yet as I am a new user)
Many hosts have their docroot (the directory on the server into which all pages are put, but which never actually figures in a URL) as public_html, public-html or similar; some have ‘www’, for instance.
Have you tried putting the path as ‘/’?
Under some circumstances where this is the case you can end up fighting a permissions issue.
Which could also be the case if ‘rw_common/themes/boreal/consolidated.css’ isn’t publishing, or can’t be published/overwritten.
Have you got a File Manager or Control Panel - or better still ftp or ssh access to your docket?
If you keep a copy of everything you could try deleting all the files in all past failed publishes, and trying again from scratch.
OK I’ll try. I have control panel access (CPanel) via web hosting where I can see file directories from the upload. Again difficult to explain as I cannot attach a screenshot here being a new person.
First keep ing a backup of everything
Then deleting everything - ON THE SERVER
Then make sure that permissions on the server for public_html are 755
Then trying again
@MarkSealey. Deleting everything on the server could have very bad side effects. I would suggest people only delete things inside the public_html folder on cPanel. Other folders behind deleted can have bad side effects ie, no emails.
CJW now has the problem resolved. For reference for anyone searching and finding this thread the path should be just public_html for most cPanel servers, not http://public_html
