Hello World,
Good Morning Weavers,
I hope you and your families are doing well in these uncertain times and you manage to enjoy the nature and not only think about work;-)
Ok, it doesn’t work completely without work and so I would like to post a question in the forum, because I can’t get ahead with a task.
I’m working at a clients timetable, based on Grid Iron 3 and Google Spreadsheet.
Everything works fine - thanks again for some helpful input from @greg and team from Chilidog;-)
Service at its best…!
One of the used columns needs a two-line entry, others only one line. For better separation of the weekdays I want to use a colored background.
With a colored background it works only with this line…
09:45 - 11:15
(I tried with a markdown code ** for bold - but it doesn’t work in this case…)
Now my question.
The two-line entry determines the dimension for one cell height and the background is ok… Seems 55 px…
But the first column is dependent on another line of code I didn’t find. Looks like a padding…?
I checked the element and realized, that I had to add this coding > line-height: 55px;
But I don’t know where - tried to change the relevant »stacks_page_page7.css« or the RW-Inspector - but It doesn’t work at all:
table#grid-iron-stacks_in_2018474_page7.dataTable tbody tr td {
color: rgba(0, 0, 0, 1.00);
font-size: 18px;
padding: 0px 0px !important;
text-align: center;
vertical-align: middle;
Here the access to the page (dot) please replace:
https://ballettschule-niederkassel(dot)de/test/
RW Version 8.6.2 (20836)
Stacks 4.0.4
Grid Iron 3.4.5
Foundry 2.2.1.0
Google Spreadsheet
I would be very happy about any help.
Roger
