I just bought a new iMac. I’m having trouble transferring my add ons and site files correctly. I also can’t fine rapid Cart 3 to transfer it. I don’t use RC Pro. HELP!
What version of RW are you using?
If you didn’t move the addons folder on your old Mac the default location for RW7 should be here:
~/Library/Containers/com.realmacsoftware.rapidweaver/Data/Library/Application Support/RapidWeaver
If you still have the old Mac and RW7 is running okay you could move the addons folder to something like Dropbox and then point the new Mac at the same folder.
Check out this video:
