Rapid Cart Pro failing Checklist with valid credentials
Anyone have any issues setting up a RapidCart Pro store?
It says I’m failing the Stripe, Email, and Amazon S3. However, the in RW it can access Amazon S3, I know the email is valid, and the Stipe API key is accurate.
That’s because you are visiting your website using a web address that’s different from the one you have set in your RapidWeaver project. Possibly a www difference.
Please update your RapidWeaver Project web address accordingly and republish the page.
@rob, thank you for you reply.
I have my RW setting set to https://www.betastacks.com/
The RCP setting is asking for the page that me ‘store’ is embedded on which is https://www.betastacks.com/store
Does this mean that my store either has to be on the home page or I have to set the main URL to https://www.betastacks.com/store?
I have redirects setup so that it always direct to https://www.
@rob, so I tried both making the store the home page as well as changing the main URL to end in /store.
Neither resolved the issue.
You have set Stacks Store URL to http://www.betastacks.com/store/rcp/index.php in Customization > Settings > General window.
The page doesn’t exist.
Please set it to the stacks page that actually contains RapidCart Pro Store stack.
Hmm, that is interesting. I am 99% certain I’ve never entered that into the settings.
I just did a “republish all files” with the original setup I had when I posted my original post. (Depicted in the photos below)
After your first reply I changed the URL in the General setting of RW to be https://www.betastacks.com/store
After that did not work I changed it back and made the Store page my home page and set the RCP Stack store URL to https://www.betastacks.com/ and republished all files.
Perhaps I misunderstood your instructions.
Can you please confirm whether or not these settings should work?
NOTE: The images kept getting edited out.
I still see RapidWeaver Project web address set to http://www.betastacks.com without https.
You can see it in Info table at https://www.betastacks.com/store/?checklist
Please update RapidWeaver Project web address accordingly and republish the page.
I hadn’t noticed that as I kept I immediately scrolling down.
The url was correct in both places. The solution was having to check “force https protocol” and then republish all files.
I think I did this before but neglected to republish all files and just published the changes.
Thanks for your help @rob
