Rapid Cart Pro: still running
Just wanted to post that Rapid Cart Pro 4 is still running on two eCommerce sites I have. I’m afraid to touch anything given it is no longer supported. Running RW Version 8.9.4 with PHP Version: 8.2.
I have tried to contact the developers, to create a button to print a packing slip, but no response.
I guess I’ll have to use ChatGPT or something to see if it can edit the code to accomplish this.
If this fails to functions at some point, what are other similar options?
Tony
HJi @tbitz,
The dev behind RapidCart Pro has gone quiet a good while back unfortunately.
It’s a good idea to look out of a replacement for the plugin, as it can stop functioning out of the blue.
There’s a number of similar products out there - give a shout if you need advice.
Erwin
Hi Erwin,
What are the other similar products?
Thanks,
Tony
/hi @tbitz,
VibraCart Pro comes to mind, as does Webshop.stack.
Erwin
Thanks Erwin!
Had a quick look at VibraCart Pro. Looks similar to RapodCart Pro. I’ll have to download the manual and look at the details.
Tony
