Rapid Weaver 7 Question
  1. How much is it?
  2. What is the differences between RW6 and RW7. I don’t listen to pod casts so can some one just put what the differences are. How is it better etc.
its a must have just for the FTP update not to go into the rest of the non announced stuff .
$99 to buy, $59 to upgrade. There’s quite a few improvements, in my opinion. The FTP is probably big for lots of people. Backups and portable documents might be big for others… Wait for the full feature list next week but I think it’s a significant upgrade.
I’m with @caffeineinjection I’m afraid. The upgrade from 5 to 6 was so horrible that I’m going to wait and see. I’m all ready - upgraded to El Capitan yesterday - and will definitely upgrade though.
Rob
Do you mean CS5? If so, no I don’t I’m afraid.
I just took a look over at roaringapps.com and CS5 apps seem to work OK in El Capo but apparently you have to install the legacy Java 6 runtime: https://support.apple.com/kb/DL1572?locale=en_US and perhaps reinstall CS5. Take a look at roaringapps.com - it’s a site to check app compatibility.
