Are they compatible? I have tried to publish a site to a Linux based server (Crazy Domains) and it all looks OK test is fine. It just comes up with directory? I think I had a problem like this before and it may have had something to do with the path like public_html/www or similar? Can anyone help or do I need a mac based server to host?
You most certainly don’t need the server to be running MacOS. Linux-based hosting works and is the most commonly used.
If you are using the same ‘Crazy Domains’ as in this link, the correct folder should be public_html.
