I’m setting up customs product pages using the Rapidcart Product stack and a selection of column, text and header stacks, for an online store that will have about 100 products, so 100 separate pages.
I was looking to create a partial so if I want to update the layout in some way I can do this once and the changes will be made across all pages.
The problem I’m having is that when I have the Rapidcart Pro Product stack inside a partial there is no way to ‘pin’ it to allow it to be edited independently from the partial, so I can’t change the product ID for each page and having the same product on each page isn’t really what I want ![]()
Appreciate if anyone has come up with a workaround for this if they could enlighten me.
Regards
Mark
