RapidMaps 3 is now available! Responsive layout and retina graphics for your maps!
Say hello to RapidMaps 3!
RapidMaps 3 is a RapidWeaver plugin that lets you add one or more maps to your website in few seconds.
Take your maps further with RapidMaps 3, featuring tons of improvements and new features, including support for responsive themes, 1200+ Retina icons, new intuitive interface and much more.
Main features:
  • Multiple pins
  • Groups
  • Custom icons
  • Areas, Paths and Circles
  • Routes
  • Panoramio
  • Traffic
  • KML layers
  • Support for every languages
  • No need to write code
…and much more!
New in RapidMaps 3:
  • Support for responsive themes
  • Retina ready
  • 1200+ Retina icons
  • Improved location search
  • Pins reordering
  • Street View
  • New, more intuitive interface
RapidMaps 3.0.9 for RW5 and
RapidMaps 3.5.3 for RW6
have just been released!
Bug Fixes
Fixes “Over Query Limit” error when showing more than 10 routes.
http://realmacsoftware.community/rapidweaver/addons/plugins/rapidmaps-3
http://4gnd.com/rapidmaps
I have Rapid Maps 2 from Omnidea (not sure whether or not it is the same company as yours, because it says 4gnd.com). Am I eligible for the discounted price?
BTW, I asked the same question on your site… :grinning:
Yes, you are.
Foreground is a brand of Omnidea srl.
@gibo – Thanks a lot, I will make a purchase.
RapidMaps 3.5.4 for RW6 and RapidMaps 3.1.0 for RW5 have just been released!
Bug Fixes
Fixes pins sometimes not showing up when loading a project.
Fixes pin dragging issue which led to incorrect data associated with other pins.
http://rapidweavercommunity.com/addons/plugins/rapidmaps-3
Hello,
is there any way to have multiple maps on one page?
Thank you
Hi Martin,
RapidMaps supports a single map for each page.
@gibo
Do you know if it does hiking trails?
If trails data are available in KML format, RapidMaps will be able to render them:
http://help.4gnd.com/kb/rapidmaps-3-manual/6-customizing-the-map#feed
##RapidCart Pro 3.5.5 has just been released!
Bug Fixes
Removes weather layer, which is no longer supported by Google Maps API.
Fixes corrupted link for MarkerClustererPlus JS script.
##RapidCart Pro 3.5.6 has just been released!
Bug Fixes
Fixes missing Google API key error in published projects.
Enhancements
Improves Google Maps API loading.
