RapidWeaver 6.3.4 Beta
Hi Guys
We’ll be launching RapidWeaver 6.3.4 later this week: to verify a fix, we’re publishing a beta that should fix issues where RapidWeaver would re-upload all your files after a restart of the app.
Changes in RapidWeaver 6.3.4
  • Fixes a problem where the publishing history of a project would be ignored when opening a project, causing RapidWeaver to re-publish all files.
  • Fixes a problem where RapidWeaver could crash when quitting.
  • RapidWeaver now disables the “Publish” button if there are no changes to be published.
  • Improves preview reload behaviour in the Contact Form plugin when editing content in the Page Inspector.
  • Fixes a problem where Google Font requests would not load in Preview.
If you’re happy with the risks associated with the use of pre-release software, you can download RapidWeaver 6.3.4 Beta.
—Nik
Works perfectly :wink: Thank you!
Awesome to hear. Stay tuned for a final release in the next couple of days.
Thanks, works perfectly once again!
Looks good here too, I no longer have to keep projects open :slight_smile:
This is very fast and didn’t crash when I closed it. I had downgraded to 6.2.2 after the last release and this beta looks like it might be a tremendous improvement!! I’ll try to ‘break’ it tomorrow morning and post my results. Again, this looks really good and I Thank You.
Great to hear. Thanks for all your feedback!
