nikf
(Nik Fletcher)
1
Hi folks
Just a quick beta update for you today, to include a couple of changes made as part of our work on RapidWeaver 7.
New in RapidWeaver 6.3.8
- Fixes a problem where website URLs in an XML sitemap would contain extra forward slashes.
- Other minor fixes and enhancements, including improved security when checking for updates.
If you’re happy with the risks associated with pre-release software, you can download the beta here
Cheers!
—Nik
nikf
(Nik Fletcher)
2
New RapidWeaver 6.3.8 beta now available:
- Improves document loading error message when opening a corrupted project file.
- Adds a new setting to the launch options window: you can now reset the RapidWeaver document window by holding Option when launching RapidWeaver.
- Fixes a problem where welcome window links would take you to an incorrect page.
Download Link
nikf
(Nik Fletcher)
3
Just one further quick revision:
https://dl.devmate.com/com.realmacsoftware.rapidweaver6/15165/1456741409/RapidWeaver6-15165.zip
Updates the problem reporter, and update checking, frameworks to the most recent versions.
—Nik
Turtle
(Brad Halstead)
4
Thanks for the hard work folks!
Already I notice projects loading faster and some idiosyncrasies have been squashed in this version!
Brad
