When I try to start RW7 on my MacBook Pro, it gets stuck in the open file window. All .rw files are greyed out. And if I click on open or cancel, it closes and immediately reopens the window. If I try to open RW by double-clicking a .rw file, I get caught in the same loop. The only way out it is to force-close RW.
I re-downloaded the app but the same thing occurs.
I have High Sierra and I recently updated some music software on this computer, and hadn’t started RW in a while (I work mostly from my iMac). Music software is famous for disrupting links and settings, so maybe something happened that interferes with RW.
Are there RW files in other places in my system that may be corrupt or pointing to places that may not exist anymore?
Does anyone have any ideas? I am about to hit the road for two months and need to keep updating my RW sites.
Terry Vosbein
