RapidWeaver 8.1 Final Candidate 4 (Build 20514b)
Het Weavers!
This build contains various bug fixes and enhancements. Much more stable than the last build. I think we’re almost ready for prime-time with this one…
Please keep the feedback coming, we’re working hard to make this the most stable version yet.
Happy Weaving.
What’s New in RapidWeaver 8.1?
  • Sandboxed!
  • Dark Mode for Mojave now supported
  • Added Amazon S3 as a Publishing Destination
  • Touch Bar support added
  • Added support for resizing the preview in the main window
  • Added support back in for copying a resources URL
  • Added a new drop down menu to the Simulator toolbar button
  • Added iPhone XS Max to the simulator window
  • Added an option to disable OpenGraph metatags on a per page basis
  • Add a new preference to disable UI sounds
  • Multiple selection is now supported in the Resources Browser
  • Resources can now be dragged from a child folder to the root resources folder
  • Source list layout is now restored between opens
  • Improved the handling of files in the Resources Manager
  • Files in the Resources Browser can now be renamed
  • Fixed an issue where the sitemap plugin and sitemap.xml was displayed and exported incorrectly
  • Fixed an issue with adding edited photos from the resources browser
  • Fixed an issue with resources not getting exported when previewing
  • Fixed an issue where RapidWeaver would appear to deadlock while opening projects
  • Fixed an issue where RapidWeaver would re-publish all files on every publish
  • Fixed an issue where RapidWeaver would get stuck looping between pages
  • Fixed an issue where the incorrect path would be used for social tags in the page header
  • Fixed an issue with multiple buy buttons showing
  • Removed the javascript that was removing line breaks from the Offroad theme
  • Fixed an issue where banner images wouldn’t show due to an issue with CSS consolidation
  • Fixed a naming issue with FontAwesome
  • Show Properties button in Blog now works correctly
  • Fixed various podcasting and channel issues within the Blog page
  • Fixed an issue with page styles being incorrectly applied to Master Styles
  • Fixed up an issue with the Addons Installer
  • Fixed up various crashes in the Photo Album Plugin
  • Fixed a crash when using “Reveal in Finder” and the resource cannot be found
  • Fixed up crash when using the link panel
  • Fixed a crash that would sometimes occur in the Snippets Window
  • Numerous other fixes and enhancements!
I understand that this is a non-final version and will probably contain bugs, but I would still like to download RapidWeaver 8.1 Final Candidate 4 (Build ** 20514b** )
looks promising … there are no bug responses
No problems noticed so far.
I can not delete a document from the file sharing page. Just crashes. I have forwarded a couple of reports so far. Thanks
New bug:
Open the contents of any theme and open the styles.css file or whatever.
Paste in some basic CSS code like this and save the changes:
body {
    background: red !important;
RapidWeaver preview reloads / refreshes. You see the preview briefly flicker. But the simple modification is not shown. Quit and restart RapidWeaver, switch into preview mode. Red background now showing correctly!
Expected result: It should be possible to edit a theme and see the changes instantly in RapidWeaver preview, without having to restart every time.
Current situation: Edits made to themes only show after quitting and restarting RapidWeaver.
RapidWeaver 8.1 (20514b)
bug found: whenever I hit “publish”, this window pops up and the publishing is aborted. When I confirm the message and publish again, it works. Same experience in various projects.
I see this too.
A new build of 8.1 is now out, grab it here: RapidWeaver 8.1 Final Candidate 5 (Build 20536b) *UPDATED* (Link Fixed)
