my Version of RapidWeaver 8.6.2 worked fine. I updated to 8.7 and first everything worked well. Yesterday Rapidweaver 8.7 crashed always right from the start.
I disabled all of may stacks but that made no difference - Rapidweaver crashed.
So I downloaded 8.6.2 again and named it ‚Rapidweaver 8.6‘. Now, that one worked again! But Rapidweaver 8.7 (named ‚Rapidweaver‘ on may machine, kept crashing.
So I deleted Rapidweaver 8.7. Now I could rename ‚Rapidweaver 8.6‘ (which worked) to ‚Rapidweaver‘. This time it crashed also.
I renamed it in ‚Rapidweaver 8.6‘ and it works again.
I think it is likely, that a preference related to ‚Rapidweaver‘ (but not related to ‚Rapidweaver 8.6‘) is damaged. So the best would be, to delete it.
But which one should I delete?
Or am I wrong and there ist a totally different mistake?
Hello teefers!
Thank you.
How do I contact them?
I now namend Rapidweaver (8.7) ‘Rapidweaver 8.7’ and that seems to work.
But I still would like to know which preferences I should delete!
There used to be some knowledge base articles on some of this stuff, but RealMac decided to ”redesign” their site and removed them before having replacement information available.
I had two RW crashes yesterday during a fairly lengthy session. At the time I thought it was probably a memory issue and closed down a bunch of other open apps and made sure that I always made a new version of the project before making any major changes. I guess two crashes in one day is slightly unusual compared to normal.
