RapidWeaver Favicon format
At this web site https://perishablepress.com/everything-you-ever-wanted-to-know-about-favicons/
I’ve read that contrary to popular opinion Favicons can be any of the following formats .ico .gif .png .jpg
RapidWeaver 7 however won’t let me use anything but an .ico format (the only format I can not create with with the software I have, Photoshop Elements).
Why won’t RapidWeaver allow the use of these other formats?
I’m pretty sure you can just rename your .jpg favicon to .ico after you’ve created it.
Try this site https://realfavicongenerator.net
It’ll generate all the icons you’ll need and if you choose not to use the new RW8 method of managing the icons you can paste the provided code into your settings>code>head setction
Thanks NeilUK this does seem to work! Although it’s not clear to me why RapidWeaver won’t accept any other favicon file format to begin with.
RapidWeaver 8 has redone the entire web icon area.
Checkout item 6:
https://blog.realmacsoftware.com/why-rapidweaver-8-is-a-must-have-upgrade/
Ah, I see, that would be helpful!
