Hello community,
Almost a decade has passed since the last website I created using RapidWeaver 4 or 5 I don’t remember. I need to create a new website and I am considering using again RapidWeaver, since I was very happy the last time I used it.
I have lots of paid plugins like stacks, blocks, simple columns stack, simple definitions stack, accordion and others I need to dig in. Are you aware of any upgrade options available to update all this old components ?
I need to create online forms, which on submission I need to create a record in a FileMaker database, using the Data API call. Will this be as easy as i.e. JotForm or I need to create custom code to make the call ?
Whats the most malleable theme to be used nowadays ? back in the time I purchased several themes, but I ended up using a free theme which was offering endless opportunities of customization.
Does the RapidWeaver eCommerce store have an API cURL compatible to sync products between website and FileMaker database ?
Thanks for the insights !
