zunaid
(Zunaid)
1
Hi everyone
I’m new to RapidWeaver. I generally use Wordpress but I’m tired of the continual updates of plugins and themes.
I’m planning to get Stacks + Foundry from the initial research I did.
I have a question regarding form entries.
Is there any easy way to store these entries?
Since, from what I understand, RapidWeaver doesn’t use a mysql database natively, I imagine I would have to use some sort of add-on ?
If you want to use MySQL I suggest a stack such as FormSnap.
I use Foundation as it is a bit easier to use, but that is up to you.
teefers
(Doug Bennett)
3
Formloom offers mySQL support. I don’t think there’s any sort of backend with any of them to view or edit the mySQL data.
A number of RapidWeaver users that need more sophisticated form processing use outside products like Machforms.
swilliam
(scott williams)
4
Foundation has the ability to use custom post if you can write a few lines of php you can store to database csv file etc.
Here is another way…
Just have the output setup this way and copy and paste into a text editor and save as a csv file:
yabdab
(yabdab)
6
Formloom 4 does offer a backend for viewing saved data.
teefers
(Doug Bennett)
7
Great to know, I’ve never used the mySQL portion.
zunaid
(Zunaid)
8
Thanks I’ll check it out.
hybridrcg
(Riaan Grobler)
9
Can you please give more details on this Mike? Formloom Manual don’t say much about it.
system
(system)
Closed
10
