When I import pictures into RW8.3 it crashes. RW7 is ok. Is there a fix on the way?
Please see this thread:
I tried downloading 8.4 beta without any success
What was the error message? Without any success doesn’t help much.
No error message. I downloaded the
Kate Hubball
I have installed RW 8.4 but it still crashes when I try to insert a photo/picture.
I am using Will Woodgates’ Bootstrap theme. I have no problem if I use RW7.
I’ll try different themes and see what happens.
Two things:
Post the crash report if you get one.
If you get a dialog box (either immediately, after a little while, or sometimes when you next launch the app) that has a “Report” button on it then click the button. Select the text in the window and paste here or include as an attachment. This will help plugin developers identify if there is a plugin issue and how to fix it when there is. -
Try without any plugins – just as a test, not as a permanent solution. You can start RW with the Option key held down – then it will ask you if you want to run without your addons. Try this. If it works then you know the issue is in one of your addons.
If it is your addons, then it’s likely your plugins – especially if you haven’t upgraded in a while. Every plugin has had to be re-released sometime in the past couple months to add support for Catalina.
If you identify which plugin/plugins – then start by downloading fresh versions from the developers websites. You can find YourHead plugins here: http://yourhead.com
If the problem persists after upgrading the plugin, contact the plugin author for assistance – and make sure to show them the crash report.
Isaiah
Here’s the first part of the report whenRW8 crashes.
Process: RapidWeaver 8 [46057]
Path: /Volumes/VOLUME/*/RapidWeaver 8-4.app/Contents/MacOS/RapidWeaver 8
Identifier: com.realmacsoftware.rapidweaver8
Version: 8.4 (20812b)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: RapidWeaver 8 [46057]
User ID: 501
Date/Time: 2019-10-14 09:13:12.726 +0100
OS Version: Mac OS X 10.15 (19A583)
Report Version: 12
Anonymous UUID: 801582B0-0094-5CD1-05F8-CBC060F88A31
Sleep/Wake UUID: 3E4FFA05-3997-434F-A349-F2BEF1B0BFC6
Time Awake Since Boot: 76000 seconds
Time Since Wake: 34000 seconds
System Integrity Protection: enabled
Notes: Translocated Process
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Illegal instruction: 4
Termination Reason: Namespace SIGNAL, Code 0x4
Terminating Process: exc handler [46057]
Application Specific Information:
Crashing on exception: *** -[__NSDictionaryM setObject:forKeyedSubscript:]: key cannot be nil
˜ß’áˇ
Hope this helps.
M Hubball
HI. I upgraded to Stacks 4 and the problem went away.
Regards to all.
M Hubball
Crashing again after stacks 4 update.
Process: RapidWeaver 8 [46685]
Path: /private/var/folders/*/RapidWeaver 8-4.app/Contents/MacOS/RapidWeaver 8
Responsible: RapidWeaver 8 [46685]
User ID: 501
Date/Time: 2019-10-14 09:53:09.680 +0100
Report Version: 12
Time Awake Since Boot: 78000 seconds
Time Since Wake: 37000 seconds
Terminating Process: exc handler [46685]
__Crashing on exception: *** -[NSDictionaryM setObject:forKeyedSubscript:]: key cannot be nil
˜ß’ᡇXÉ
There’s a clue here.
Regards
Is there any more to the crash report? Usually it would contain a stack track after this bit – and that’s really the most important part.
Hi Isaiah
The report ran into 6 or so pages. I tried to send the whole lot but it was rejected because it was too large. I’ll chop it into several chunks and send the report again.
Mike
1st page of crash report
Process: RapidWeaver 8 [61227]
Responsible: RapidWeaver 8 [61227]
User ID: 501
Date/Time: 2019-10-15 09:34:22.759 +0100
Report Version: 12
Sleep/Wake UUID: 859D7CA9-4779-4547-BA46-73F4F6DE189B
Time Awake Since Boot: 150000 seconds
Terminating Process: exc handler [61227]
˜ß’áˇ
Application Specific Backtrace 1:
0 CoreFoundation 0x00007fff36eacd63 __exceptionPreprocess + 250
1 libobjc.A.dylib 0x00007fff6cd9bbd4 objc_exception_throw + 48
2 CoreFoundation 0x00007fff36f6fe0a _CFThrowFormattedException + 202
3 CoreFoundation 0x00007fff36f7aa38 -[__NSDictionaryM setObject:forKeyedSubscript:].cold.2 + 0
4 CoreFoundation 0x00007fff36e09988 -[__NSDictionaryM setObject:forKeyedSubscript:] + 1000
5 RapidWeaver 8 0x000000010f94a74d __51-[MyDocument addResourcesForURLs:toFolder:atIndex:]_block_invoke + 264
6 CoreFoundation 0x00007fff36efd367 NSARRAY_IS_CALLING_OUT_TO_A_BLOCK + 7
7 CoreFoundation 0x00007fff36e499a9 -[__NSArrayM enumerateObjectsWithOptions:usingBlock:] + 224
8 RapidWeaver 8 0x000000010f947ba1 -[MyDocument addResourcesForURLs:toFolder:atIndex:] + 337
9 RapidWeaver 8 0x000000010f9b7bdf __88-[NSPasteboard(ResourceBrowser) processDraggedFilesForDocument:folder:index:completion:]_block_invoke.30 + 46
10 libdispatch.dylib 0x00007fff6e0aa4de _dispatch_client_callout + 8
11 libdispatch.dylib 0x00007fff6e0ac690 _dispatch_continuation_pop + 414
12 libdispatch.dylib 0x00007fff6e0bc3c8 _dispatch_source_invoke + 2084
13 libdispatch.dylib 0x00007fff6e0b5a91 _dispatch_main_queue_callback_4CF + 783
14 CoreFoundation 0x00007fff36dfc290 CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE + 9
15 CoreFoundation 0x00007fff36dfb9da __CFRunLoopRun + 2370
16 CoreFoundation 0x00007fff36dfae13 CFRunLoopRunSpecific + 499
17 HIToolbox 0x00007fff35987b2d RunCurrentEventLoopInMode + 292
18 HIToolbox 0x00007fff3598786d ReceiveNextEventCommon + 600
19 HIToolbox 0x00007fff359875f7 _BlockUntilNextEventMatchingListInModeWithFilter + 64
20 AppKit 0x00007fff3401dac4 _DPSNextEvent + 990
21 AppKit 0x00007fff3401c834 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1352
22 AppKit 0x00007fff34016fd4 -[NSApplication run] + 658
23 AppKit 0x00007fff34008e7d NSApplicationMain + 777
24 libdyld.dylib 0x00007fff6e0fa405 start + 1
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.apple.AppKit 0x00007fff343cbed7 -[NSApplication _crashOnException:] + 106
1 com.apple.AppKit 0x00007fff343cbdbd -[NSApplication reportException:] + 908
2 com.realmacsoftware.rapidweaver8 0x000000010f889820 CLSNSApplicationReportException(objc_object*, objc_selector*, NSException*) + 69
3 com.apple.AppKit 0x00007fff34483b97 uncaughtErrorProc + 145
4 com.apple.CoreFoundation 0x00007fff36f309b0 __handleUncaughtException + 726
5 libobjc.A.dylib 0x00007fff6cd9daa4 _objc_terminate() + 90
6 com.realmacsoftware.rapidweaver8 0x000000010f889584 CLSTerminateHandler() + 355
7 libc++abi.dylib 0x00007fff6b2a8da7 std::__terminate(void (*)()) + 8
8 libc++abi.dylib 0x00007fff6b2a8d59 std::terminate() + 41
9 libdispatch.dylib 0x00007fff6e0aa4f2 _dispatch_client_callout + 28
10 libdispatch.dylib 0x00007fff6e0ac690 _dispatch_continuation_pop + 414
11 libdispatch.dylib 0x00007fff6e0bc3c8 _dispatch_source_invoke + 2084
12 libdispatch.dylib 0x00007fff6e0b5a91 _dispatch_main_queue_callback_4CF + 783
13 com.apple.CoreFoundation 0x00007fff36dfc290 CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE + 9
14 com.apple.CoreFoundation 0x00007fff36dfb9da __CFRunLoopRun + 2370
15 com.apple.CoreFoundation 0x00007fff36dfae13 CFRunLoopRunSpecific + 499
16 com.apple.HIToolbox 0x00007fff35987b2d RunCurrentEventLoopInMode + 292
2nd page of crash report
17 com.apple.HIToolbox 0x00007fff3598786d ReceiveNextEventCommon + 600
18 com.apple.HIToolbox 0x00007fff359875f7 _BlockUntilNextEventMatchingListInModeWithFilter + 64
19 com.apple.AppKit 0x00007fff3401dac4 _DPSNextEvent + 990
20 com.apple.AppKit 0x00007fff3401c834 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1352
21 com.apple.AppKit 0x00007fff34016fd4 -[NSApplication run] + 658
22 com.apple.AppKit 0x00007fff34008e7d NSApplicationMain + 777
23 libdyld.dylib 0x00007fff6e0fa405 start + 1
Thread 1:: JavaScriptCore bmalloc scavenger
0 libsystem_kernel.dylib 0x00007fff6e2468f6 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff6e307082 _pthread_cond_wait + 701
2 libc++.1.dylib 0x00007fff6b24b81a std::__1::condition_variable::wait(std::__1::unique_lockstd::__1::mutex&) + 18
3 com.apple.JavaScriptCore 0x00007fff3b4bf714 void std::__1::condition_variable_any::wait<std::__1::unique_lockbmalloc::Mutex >(std::__1::unique_lockbmalloc::Mutex&) + 84
4 com.apple.JavaScriptCore 0x00007fff3b4c3c2b bmalloc::Scavenger::threadRunLoop() + 331
5 com.apple.JavaScriptCore 0x00007fff3b4c37a9 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9
6 com.apple.JavaScriptCore 0x00007fff3b4c5fc7 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_deletestd::__1::__thread_struct >, void ()(bmalloc::Scavenger), bmalloc::Scavenger*> >(void*) + 39
7 libsystem_pthread.dylib 0x00007fff6e306d76 _pthread_start + 125
8 libsystem_pthread.dylib 0x00007fff6e3035d7 thread_start + 15
Thread 2:: com.apple.NSURLConnectionLoader
0 libsystem_kernel.dylib 0x00007fff6e243146 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff6e2436ac mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff36dfc19b __CFRunLoopServiceMachPort + 322
3 com.apple.CoreFoundation 0x00007fff36dfb737 __CFRunLoopRun + 1695
4 com.apple.CoreFoundation 0x00007fff36dfae13 CFRunLoopRunSpecific + 499
5 com.apple.CFNetwork 0x00007fff355d231e 0x7fff3558c000 + 287518
6 com.apple.Foundation 0x00007fff3948def2 NSThread__start + 1064
Thread 3:: com.twitter.crashlytics.mac.MachExceptionServer
0 libsystem_kernel.dylib 0x00007fff6e24702a write + 10
1 com.realmacsoftware.rapidweaver8 0x000000010f87f317 CLSSDKFileLog + 375
2 com.realmacsoftware.rapidweaver8 0x000000010f8772fd CLSMachExceptionServer + 938
3 libsystem_pthread.dylib 0x00007fff6e306d76 _pthread_start + 125
4 libsystem_pthread.dylib 0x00007fff6e3035d7 thread_start + 15
Thread 4:: com.apple.coreanimation.render-server
2 com.apple.QuartzCore 0x00007fff42651566 CA::Render::Server::server_thread(void*) + 958
3 com.apple.QuartzCore 0x00007fff4265119d thread_fun(void*) + 25
4 libsystem_pthread.dylib 0x00007fff6e306d76 _pthread_start + 125
5 libsystem_pthread.dylib 0x00007fff6e3035d7 thread_start + 15
Thread 5:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fff34025026 _NSEventThread + 132
6 libsystem_pthread.dylib 0x00007fff6e306d76 _pthread_start + 125
7 libsystem_pthread.dylib 0x00007fff6e3035d7 thread_start + 15
Thread 6:
2 com.apple.AppleVPAFramework 0x00007fff4a6f892e 0x7fff4a6d0000 + 166190
Thread 7:
0 libsystem_pthread.dylib 0x00007fff6e3035b4 start_wqthread + 0
Thread 8:
Thread 9:
Thread 10:
page 3
Thread 11:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00007fbb99868000 rbx: 0x0000600007c4da10 rcx: 0x250d05b4d5860045 rdx: 0x0000000000000000
rdi: 0x00006000063f43f0 rsi: 0x00000000000009f0 rbp: 0x00007ffee0392020 rsp: 0x00007ffee0392010
r8: 0x00000000000001f0 r9: 0x00007fbb998689f0 r10: 0x00000000000001f0 r11: 0x0000000000000000
r12: 0x00007fff6cd8f750 r13: 0x000060000c996b80 r14: 0x00007fff6cd8f880 r15: 0x00007fbb8f50d260
rip: 0x00007fff343cbed7 rfl: 0x0000000000010202 cr2: 0x00000001139d4af0
Logical CPU: 0
Error Code: 0x00000000
Trap Number: 6
Binary Images:
0x10f86c000 - 0x10fa5efff +com.realmacsoftware.rapidweaver8 (8.4 - 20812b) /var/folders//RapidWeaver 8-4.app/Contents/MacOS/RapidWeaver 8
0x10fc6e000 - 0x10fcb4fff +org.sparkle-project.Sparkle (1.20.0 885-g3569b46d - 1.20.0) <11AEEF0F-D83E-3AAB-8E27-00787BC1F64E> /var/folders//RapidWeaver 8-4.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
0x10fd24000 - 0x10fd2cfff +com.realmacsoftware.rmfoundation (1.0 - 1) <45061EFB-E4B4-3AD0-8146-54461AE0D79F> /var/folders//RapidWeaver 8-4.app/Contents/Frameworks/RMFoundation.framework/Versions/A/RMFoundation
0x10fd3c000 - 0x10ffe6527 +com.realmacsoftware.ftp (1.0 - 1) /var/folders//RapidWeaver 8-4.app/Contents/Frameworks/RMFTP.framework/Versions/A/RMFTP
0x1100cc000 - 0x11011fffb +com.realmacsoftware.RMKit (2.0) /var/folders//RapidWeaver 8-4.app/Contents/Frameworks/RMKit.framework/Versions/A/RMKit
0x1101af000 - 0x1102caffb +com.realmacsoftware.RWKit (1.0 - 88) <064ACF6B-F184-3097-B60D-0E7A8EEF77CB> /var/folders//RapidWeaver 8-4.app/Contents/Frameworks/RWKit.framework/Versions/A/RWKit
0x11036c000 - 0x1103bdfff +com.realmacsoftware.SquashFramework (1.0 - 1) <2014668D-5B1C-37F4-AA7A-CEFC98D03934> /var/folders//RapidWeaver 8-4.app/Contents/Frameworks/Squash.framework/Versions/A/Squash
0x1103ec000 - 0x110464fff +com.paddle.Paddle (3.0.24 - 189) /var/folders//RapidWeaver 8-4.app/Contents/Frameworks/Paddle.framework/Versions/A/Paddle
0x1104c5000 - 0x1104e2fff +com.ziparchive.ZipArchive (1.0 - 1) <57E0DFC4-D0E4-33FF-BD6B-B89063190F76> /var/folders//RapidWeaver 8-4.app/Contents/Frameworks/ZipArchive.framework/Versions/A/ZipArchive
0x11233f000 - 0x112349fff +com.realmacsoftware.rwplugin.FileSharing (7.0 - 100) <3F4E32E2-7946-336F-9AFD-6D13C48B3384> /var/folders//RapidWeaver 8-4.app/Contents/PlugIns/FileSharing.rapidweaverplugin/Contents/MacOS/FileSharing
0x11235f000 - 0x11236dfff +com.realmacsoftware.rwplugin.ContactForm (7.0 - 100) <931DCCCB-0C66-33E9-8E2E-23C50913DB52> /var/folders//RapidWeaver 8-4.app/Contents/PlugIns/Contact Form.rapidweaverplugin/Contents/MacOS/Contact Form
0x112386000 - 0x112389fff +com.realmacsoftware.rwplugin.HTML (7.0 - 100) /var/folders//RapidWeaver 8-4.app/Contents/PlugIns/HTML.rapidweaverplugin/Contents/MacOS/HTML
0x112392000 - 0x112395fff +com.realmacsoftware.rwplugin.iFrame (7.0 - 100) <87A7C351-86B1-39C2-8532-65CFFE978142> /var/folders//RapidWeaver 8-4.app/Contents/PlugIns/iFrame.rapidweaverplugin/Contents/MacOS/iFrame
0x11239e000 - 0x1123a1fff +com.realmacsoftware.rwplugin.Markdown (7.0 - 100) /var/folders//RapidWeaver 8-4.app/Contents/PlugIns/Markdown.rapidweaverplugin/Contents/MacOS/Markdown
0x1123aa000 - 0x1123aefff +com.realmacsoftware.rwplugin.OffsitePage (7.0 - 100) <1A303C66-99E6-3776-803F-02C977734CEA> /var/folders//RapidWeaver 8-4.app/Contents/PlugIns/OffsitePage.rapidweaverplugin/Contents/MacOS/OffsitePage
0x11242f000 - 0x11243aff7 +com.realmacsoftware.rwplugin.MovieAlbum (7.0 - 100) <9B59FA8F-98BF-36A4-BFB6-FADB02C14919> /var/folders//RapidWeaver 8-4.app/Contents/PlugIns/Movie Album.rapidweaverplugin/Contents/MacOS/Movie Album
0x112446000 - 0x112449fff +com.realmacsoftware.rwplugin.StyledText (7.0 - 100) <8A23419F-45D5-36A9-98E7-BBADA746422D> /var/folders//RapidWeaver 8-4.app/Contents/PlugIns/Styled.rapidweaverplugin/Contents/MacOS/Styled
0x112461000 - 0x11247eff3 +com.realmacsoftware.rwplugin.PhotoAlbum (7.0 - 100) /var/folders//RapidWeaver 8-4.app/Contents/PlugIns/PhotoAlbum.rapidweaverplugin/Contents/MacOS/PhotoAlbum
0x1124d7000 - 0x1124dffff +com.realmacsoftware.rwplugin.Quicktime (7.0 - 100) /var/folders//RapidWeaver 8-4.app/Contents/PlugIns/Quicktime.rapidweaverplugin/Contents/MacOS/Quicktime
0x11276c000 - 0x112772ffb +com.realmacsoftware.rwplugin.Sitemap (7.0 - 26) /var/folders//RapidWeaver 8-4.app/Contents/PlugIns/Sitemap.rapidweaverplugin/Contents/MacOS/Sitemap
0x113536000 - 0x113539047 libobjc-trampolines.dylib (779.1) /usr/lib/libobjc-trampolines.dylib
0x113ae2000 - 0x113ae3ffb com.apple.AddressBook.LocalSourceBundle (11.0 - 2419.1) <05A02AF7-5499-300A-8497-1B17DB4E7C8D> /System/Library/Address Book Plug-Ins/LocalSource.sourcebundle/Contents/MacOS/LocalSource
0x11454f000 - 0x114553ffb com.apple.DirectoryServicesSource (11.0 - 2419.1) <770D22DF-961B-3B1E-9ED4-CB9F8BDAD754> /System/Library/Address Book Plug-Ins/DirectoryServices.sourcebundle/Contents/MacOS/DirectoryServices
0x11511a000 - 0x11511cff3 com.apple.CloudDocsFileProvider (1.0 - 679) <698DFD87-41B4-3A10-9FA9-A6CFB11F792B> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider
0x115536000 - 0x115539fff com.apple.FileProviderOverride (253 - 253) <412919D0-E777-3F28-A046-8F500DDB671F> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
0x1163c2000 - 0x1163d9ffb com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride (1.0 - 1298.0.12) <85A2947C-7855-3B2E-B61B-E7691E776ABD> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
0x1169c0000 - 0x116a02ff3 +com.realmacsoftware.rwplugin.Blog (7.0 - 100) <1DA9F0F4-6213-3F83-9458-9415A777A4BB> /var/folders//RapidWeaver 8-4.app/Contents/PlugIns/Blog.rapidweaverplugin/Contents/MacOS/Blog
0x117274000 - 0x1172ebfff com.apple.AddressBook.CardDAVPlugin (10.9 - 1059.3) <44071222-BA73-34DA-95BF-2625B96FFB81> /System/Library/Address Book Plug-Ins/CardDAVPlugin.sourcebundle/Contents/MacOS/CardDAVPlugin
0x117399000 - 0x11768bff7 +YHStacksPlugin (4.0.3 - 4795) /Users/USER/Library/Group Containers//Stacks
0x118628000 - 0x1186eeff7 com.apple.AMDRadeonX4000GLDriver (3.0.68 - 3.0.0) /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0x118877000 - 0x11890593f dyld (732.8) <42C11B81-6928-369F-B03E-D57355572700> /usr/lib/dyld
0x1268db000 - 0x1268ddff3 com.apple.AppleIntelSKLGraphicsVAME (14.0.69 - 14.0.0) <00C36DA6-BB65-3F61-A120-BB90B89A4B1A> /System/Library/Extensions/AppleIntelSKLGraphicsVAME.bundle/Contents/MacOS/AppleIntelSKLGraphicsVAME
0x138ae7000 - 0x13a38fff7 com.apple.AppleIntelSKLGraphicsVADriver (14.0.69 - 14.0.0) <1F34EDEC-D607-346C-A70C-A068F204184A> /System/Library/Extensions/AppleIntelSKLGraphicsVADriver.bundle/Contents/MacOS/AppleIntelSKLGraphicsVADriver
0x7fff2a397000 - 0x7fff2a5e6ff8 com.apple.RawCamera.bundle (9.00.1 - 1300.22) /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff2a5e9000 - 0x7fff2a704ffe com.apple.AMDMTLBronzeDriver (3.0.68 - 3.0.0) <3810A315-7F73-32B6-BDBB-1C5FC25D4D8F> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x7fff2a705000 - 0x7fff2b0a5ff7 ATIRadeonX4000SCLib.dylib (3.0.68) /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x7fff327c4000 - 0x7fff329bbff2 com.apple.avfoundation (2.0 - 1722.27.4.5) /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff329bc000 - 0x7fff32a87ff8 com.apple.audio.AVFAudio (1.0 - ???) <2ED23D7A-9635-3D52-BEFE-3044062B023A> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff32a89000 - 0x7fff32ba6ff1 com.apple.AVKit (1.1 - 587.7) <0D605DBB-C339-3B2C-BFC9-6F4A27D695C1> /System/Library/Frameworks/AVKit.framework/Versions/A/AVKit
0x7fff32ba7000 - 0x7fff32ba7fff com.apple.Accelerate (1.11 - Accelerate 1.11) <956D070C-B522-3A08-891A-CAD6BA4082D1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff32ba8000 - 0x7fff32bbeff7 libCGInterfaces.dylib (524.2) <7F08322A-4AA0-3677-91CD-9D1588BDBE39> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff32bbf000 - 0x7fff3322afdf com.apple.vImage (8.1 - 524.2) <45A48EA9-49AA-33A0-B830-AF754BD01009> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff3322b000 - 0x7fff33493fff libBLAS.dylib (1303) <112B19CC-925A-3E28-8B32-2002D30A37FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff33494000 - 0x7fff33783fdf libBNNS.dylib (144.11.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff33785000 - 0x7fff33b2afff libLAPACK.dylib (1303) <5C248B39-F233-3074-A3A5-AF8F436FBF87> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff33b2b000 - 0x7fff33b40ff8 libLinearAlgebra.dylib (1303) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff33b41000 - 0x7fff33b46ff3 libQuadrature.dylib (7) <826897ED-B7AD-33DC-B9CB-F9787784F312> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff33b47000 - 0x7fff33bb7fff libSparse.dylib (103) <55467C29-2096-36AB-8A6D-5231A342809D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff33bb8000 - 0x7fff33bcafef libSparseBLAS.dylib (1303) <3244FCAF-A1FE-3248-AF22-BFB3E9D12555> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff33bcb000 - 0x7fff33da4ffb libvDSP.dylib (735) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff33da5000 - 0x7fff33e60fd3 libvMisc.dylib (735) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff33e61000 - 0x7fff33e61fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <79C1A1C7-E97A-3B7A-8737-444B402A7AA0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff33e62000 - 0x7fff33ec0ffc com.apple.Accounts (113 - 113) <33BCDB9E-2E27-3D12-B895-826145D156BC> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff33ec2000 - 0x7fff34005ff4 com.apple.AddressBook.framework (11.0 - 2419.1) <142E6662-3525-32C2-946D-1CFBCFE55F92> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fff34006000 - 0x7fff34db2ff9 com.apple.AppKit (6.9 - 1894) <1F4FBEF8-F3AC-31C2-BF04-381BC72E36D1> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff34df1000 - 0x7fff34e01ff7 com.apple.AppleScriptObjC (1.4 - 35) /System/Library/Frameworks/AppleScriptObjC.framework/Versions/A/AppleScriptObjC
0x7fff34e02000 - 0x7fff34e02fff com.apple.ApplicationServices (48 - 50) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff34e03000 - 0x7fff34e6efff com.apple.ApplicationServices.ATS (377 - 493) <0EB214FD-E4D6-3045-A0A6-DCBCAE5F4165> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff34f07000 - 0x7fff34f45ffa libFontRegistry.dylib (274) <1A3CE39E-14E7-338E-B1E5-7FA79B9B0065> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff34fa0000 - 0x7fff34fcfff7 com.apple.ATSUI (1.0 - 1) <9391C527-15CE-3108-8922-CF0C2A50C082> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff34fd0000 - 0x7fff34fd4ff3 com.apple.ColorSyncLegacy (4.13.0 - 1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff3506f000 - 0x7fff350c5ffa com.apple.HIServices (1.22 - 672) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff350c6000 - 0x7fff350d4fff com.apple.LangAnalysis (1.7.0 - 1.7.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff350d5000 - 0x7fff3511aff2 com.apple.print.framework.PrintCore (15 - 516) <43213BE5-C5E1-3AA8-8AFD-949AFF9FB2C5> /
page 4
System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff3511b000 - 0x7fff35125fff com.apple.QD (4.0 - 413) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff35126000 - 0x7fff35133ff0 com.apple.speech.synthesis.framework (9.0.22 - 9.0.22) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff35134000 - 0x7fff35214ffa com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <83A9998E-0669-326F-BA80-350FC70912E6> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff35216000 - 0x7fff35216fff com.apple.audio.units.AudioUnit (1.14 - 1.14) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff35355000 - 0x7fff3555eff7 com.apple.AutomatorFramework (2.10 - 488) <032C5A3A-61EF-3CA3-B5A0-358061C90E92> /System/Library/Frameworks/Automator.framework/Versions/A/Automator
0x7fff3558c000 - 0x7fff35902ffe com.apple.CFNetwork (1111 - 1111) <642753C5-5D26-3794-9A4C-4F63F226C01A> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff35978000 - 0x7fff35978fff com.apple.Carbon (160 - 162) <098C0BD4-184D-3DAD-9915-89A5F172354F> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff35979000 - 0x7fff3597cffb com.apple.CommonPanels (1.2.6 - 101) <930A9DD4-B4BF-3D73-8B81-2D46018BB2E4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff3597d000 - 0x7fff35c71ff9 com.apple.HIToolbox (2.1.1 - 992.1) <0EA6CBC4-33C5-3BA7-B37A-1C9D5F103796> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff35c72000 - 0x7fff35c75ff3 com.apple.help (1.3.8 - 68) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff35c76000 - 0x7fff35c7bff7 com.apple.ImageCapture (9.0 - 1600.1.4.3) <87D0FDEE-8876-3E61-B349-EEB4160EBC19> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff35c7c000 - 0x7fff35c7cfff com.apple.ink.framework (10.15 - 227) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff35c7d000 - 0x7fff35c97ff2 com.apple.openscripting (1.7 - 185) <40F68E23-E438-31DC-8C8A-D2F6FBA9BBD0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff35cb8000 - 0x7fff35cb8fff com.apple.print.framework.Print (15 - 271) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff35cb9000 - 0x7fff35cbbff7 com.apple.securityhi (9.0 - 55008) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff35cbc000 - 0x7fff35cc2ff7 com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <819268CF-2A9D-3321-A826-535CB1F1E694> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff35cc3000 - 0x7fff35e5bff9 com.apple.cloudkit.CloudKit (836 - 836) <34519517-284F-301E-9A96-2CF0726E18AD> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff35e5c000 - 0x7fff35e5cfff com.apple.Cocoa (6.11 - 23) <257CF015-7450-3FD1-AC41-AB55139F3036> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff35e6a000 - 0x7fff36055ff7 com.apple.ColorSync (4.13.0 - 3394.1.4.1) <32A1AEE9-C3AA-3535-9C72-D89955D2DE85> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff36150000 - 0x7fff36285ff0 com.apple.contacts (1.0 - 3454.1) <11A97155-276C-3B49-B656-50E5277C0E05> /System/Library/Frameworks/Contacts.framework/Versions/A/Contacts
0x7fff36341000 - 0x7fff36850ffa com.apple.audio.CoreAudio (5.0 - 5.0) <88827CE9-4055-3E5F-B7C1-4E9314E6D05C> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff368a3000 - 0x7fff368daff2 com.apple.CoreBluetooth (1.0 - 1) <7FBF1402-074C-3192-95AD-5F25FE5ECD8A> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff368db000 - 0x7fff36cb5fe8 com.apple.CoreData (120 - 969.3) <7E7B66BF-2A83-3D66-8674-7F58C369B61D> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff36cb6000 - 0x7fff36dc0ff6 com.apple.CoreDisplay (1.0 - 107) <722EBF44-A989-3079-A03C-8421B10E441F> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff36dc1000 - 0x7fff37240ff7 com.apple.CoreFoundation (6.9 - 1671.15) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff37242000 - 0x7fff378bbff8 com.apple.CoreGraphics (2.0 - 1348.4.4.7) <5790BE2E-049E-39BA-B191-611CF7ECD017> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff378c9000 - 0x7fff37c25ff2 com.apple.CoreImage (15.0.0 - 900.6) <12E02841-0FB0-30F5-8444-FD925B0DE49E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff37c26000 - 0x7fff37c8cff8 com.apple.corelocation (2387.0.12.3.1 - 2387.0.12.3.1) /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff37ce1000 - 0x7fff37fe3ffa com.apple.CoreML (1.0 - 1) /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
0x7fff37fe4000 - 0x7fff380beffc com.apple.CoreMedia (1.0 - 2501.27.4.9) /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff380bf000 - 0x7fff38120ff6 com.apple.CoreMediaIO (1000.0 - 5125.1) <7434E383-DA51-33B0-B88A-ACD4BF5EB565> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff381a8000 - 0x7fff381a8fff com.apple.CoreServices (1069.2 - 1069.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff381a9000 - 0x7fff3822eff7 com.apple.AE (838 - 838) <7295ED82-7087-3602-9DCA-4FE205F6499C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff3822f000 - 0x7fff38510fff com.apple.CoreServices.CarbonCore (1217 - 1217) <7AA0ECB3-0993-3081-A9EC-0365EF72B24D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff38511000 - 0x7fff3855eff1 com.apple.DictionaryServices (1.2 - 321) <3D0FFBDE-E425-37C7-B780-39A3D024462A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff3855f000 - 0x7fff38567ff7 com.apple.CoreServices.FSEvents (1268.0.6 - 1268.0.6) <78D2AB1A-9053-3D32-8C18-C1DD31FF9400> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff38568000 - 0x7fff387a0ff1 com.apple.LaunchServices (1069.2 - 1069.2) <68B4C10C-D536-33E9-9719-E7BA5B753F2B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff387a1000 - 0x7fff38839ff1 com.apple.Metadata (10.7.0 - 2066.12) <249EA615-8446-3A36-B6B7-ED613C8B8148> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff3883a000 - 0x7fff38867ff7 com.apple.CoreServices.OSServices (1069.2 - 1069.2) <2FECF3BA-B785-35E2-85E9-2A2267801AA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff38868000 - 0x7fff388cffff com.apple.SearchKit (1.4.1 - 1.4.1) <0068BD72-CF2B-34E4-B461-002D5E56C31C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff388d0000 - 0x7fff388f4ffd com.apple.coreservices.SharedFileList (131 - 131) <61F62948-4109-38F0-BB91-5EBB6BEEAB10> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff388f5000 - 0x7fff38966ff3 com.apple.CoreSpotlight (1.0 - 2066.12) <875AFF28-A845-3BBE-A503-F08003528941> /System/Library/Frameworks/CoreSpotlight.framework/Versions/A/CoreSpotlight
0x7fff38b56000 - 0x7fff38c1bff4 com.apple.CoreTelephony (113 - 7256.3.2) /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony
0x7fff38c1c000 - 0x7fff38dd0ffe com.apple.CoreText (643.1.0.2 - 643.1.0.2) <83B0B75B-7B4A-315D-BC8B-8CB2E5D16EB8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff38dd1000 - 0x7fff38e15fff com.apple.CoreVideo (1.8 - 334.0) <54CC4AD8-7F5C-37D5-A26D-9C8C8A72BD41> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
This goes on for many pages.
Here’s the last bit
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 86
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 109440
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=759.0M resident=0K(0%) swapped_out_or_unallocated=759.0M(100%)
Writable regions: Total=1.3G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.3G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 896K 7
Activity Tracing 256K 1
CG backing stores 1760K 2
CG image 1464K 85
CG raster data 31.7M 124
CoreAnimation 363.4M 827
CoreData Object IDs 4100K 2
CoreGraphics 8K 1
CoreImage 5768K 17
CoreUI image data 5024K 41
Foundation 100.6M 218
IOKit 7940K 1
Image IO 3216K 108
Kernel Alloc Once 8K 1
MALLOC 720.6M 610
MALLOC guard page 48K 11
MALLOC_NANO (reserved) 128.0M 1 reserved VM address space (unallocated)
Mach message 8K 1
Memory Tag 242 12K 1
Memory Tag 251 16K 1
SQLite page cache 448K 7
STACK GUARD 56.0M 11
Stack 13.6M 12
VM_ALLOCATE 12.5M 56
WebKit Malloc 9380K 16
__DATA 93.4M 517
__DATA_CONST 157K 12
__FONT_DATA 4K 1
__GLSLBUILTINS 5176K 1
__LINKEDIT 354.3M 34
__OBJC_RO 31.8M 1
__OBJC_RW 1764K 2
__TEXT 404.8M 490
__UNICODE 564K 1
libnetwork 128K 8
mapped file 268.3M 182
shared memory 668K 18
TOTAL 2.6G 3429
TOTAL, minus reserved VM space 2.4G 3429
Model: iMac17,1, BootROM 173.0.0.0.0, 4 processors, Quad-Core Intel Core i5, 3.2 GHz, 8 GB, SMC 2.33f12
Graphics: kHW_AMDRadeonR9M380Item, AMD Radeon R9 M380, spdisplays_pcie_device, 2 GB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1867 MHz, 0x802C, 0x384B54463531323634485A2D314739453220
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1867 MHz, 0x802C, 0x384B54463531323634485A2D314739453220
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x14A), Broadcom BCM43xx 1.0 (7.77.105.1 AirPortDriverBrcmNIC-1429)
Bluetooth: Version 7.0.0f8, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD ST1000DM003, 1 TB
USB Device: USB 3.0 Bus
USB Device: Expansion
USB Device: USB3.0 Hub
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
USB Device: USB2.0 Hub
USB Device: Mass Storage
Thunderbolt Bus: iMac, Apple Inc., 28.1
Here’s the Apple Analytics data
09:42:24.124396+0100 RapidWeaver 8 com.apple.message.domain: com.apple.AddressBook.accounts.summary
com.apple.message.summarize: YES
com.apple.message.carddav_accounts: 2
com.apple.message.ldap_accounts: 0
com.apple.message.disabled_accounts: 0
com.apple.message.enabled_accounts: 3
com.apple.message.exchange_accounts: 0
com.apple.message.total_accounts: 4
SenderMachUUID: A539A5A1-E768-3140-8250-59471E5B56B6
09:42:24.158514+0100 RapidWeaver 8 com.apple.message.domain: com.apple.AddressBook.customPropertyDamageDetected
com.apple.message.source: SPI
com.apple.message.damaged: 0
09:42:24.162504+0100 RapidWeaver 8 com.apple.message.domain: com.apple.AddressBook.customPropertyDamageDetected
09:42:24.166387+0100 RapidWeaver 8 com.apple.message.domain: com.apple.AddressBook.customPropertyDamageDetected
09:42:47.115591+0100 Unknown com.apple.message.domain: com.apple.assumes.failure
com.apple.message.signature: 2E9076CD-6C0E-38B6-8403-B2DDCE125FBF:86780
com.apple.message.signature2: 0x89
com.apple.message.signature3: libxpc.dylib
09:42:55.963387+0100 RapidWeaver 8 OSActivityID: 0x800000000029779f
com.apple.message.domain: com.apple.open.document
com.apple.message.signature: App Recents
09:43:10.736830+0100 CoreServicesUIAgent Background App Terminated Due to Continued CPU Usage
com.apple.message.domain: com.apple.appkit.tal.autoquit
com.apple.message.signature: com.apple.coreservices.uiagent
SenderMachUUID: 164E66C6-2EB4-30AB-BCCC-34853D02E0CD
09:43:30.421273+0100 ReportCrash com.apple.message.domain: com.apple.crashreporter.writereport.crash
com.apple.message.signature: RapidWeaver 8
com.apple.message.signature2: com.realmacsoftware.rapidweaver8 ||| 8.4 (20812b)
com.apple.message.signature3: UNKNOWN
com.apple.message.result: YES
SenderMachUUID: 89DE4479-184F-30CB-BD38-F5AF0D43FF91
09:43:32.555082+0100 Problem Reporter Application stole key focus through activateIgnoringOtherApps
com.apple.message.domain: com.apple.appkit.application.stoleKeyFocus
com.apple.message.signature: com.apple.ProblemReporter
SenderMachUUID: A1D17D55-C106-3C60-9FF1-1D8C09AA1E61
09:43:33.455606+0100 Unknown com.apple.message.domain: com.apple.assumes.failure
09:43:57.270773+0100 HelpViewer com.apple.message.domain: com.apple.helpviewer.content_v3
com.apple.message.book_build_id: 5d8d70f3094622050239fb5c
com.apple.message.book_locale: en_GB
com.apple.message.book_name: macOS User Guide
com.apple.message.book_version: 10.15
com.apple.message.topic_id: MH27990
SenderMachUUID: 42AE3EE5-26FD-364A-A1D4-48B9C5BB5C65
com.apple.message.topic_title: Share analytics information from your Mac with Apple
09:45:39.431592+0100 powerd com.apple.message.domain: com.apple.darkwake.capable
com.apple.message.hardware_support: smc_without_platform
com.apple.message.settings: ac
SenderMachUUID: 0D6ABB0E-20D3-3A3D-995D-6AA8DBC6A0EF
Here’s the system log
Oct 15 09:34:22 Michaels-iMac com.apple.xpc.launchd[1] (com.realmacsoftware.rapidweaver8.2424[61227]): Service exited due to SIGILL | sent by exc handler[61227]
Oct 15 09:34:55 Michaels-iMac Problem Reporter[80721]: assertion failed: 19A583: libxpc.dylib + 86780 [2E9076CD-6C0E-38B6-8403-B2DDCE125FBF]: 0x89
Oct 15 09:35:51 Michaels-iMac syncdefaultsd[80739]: objc[80739]: Class SYDClient is implemented in both /System/Library/PrivateFrameworks/SyncedDefaults.framework/Versions/A/SyncedDefaults and /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd. One of the two will be used. Which one is undefined.
Oct 15 09:35:51 Michaels-iMac syncdefaultsd[80739]: objc[80739]: Class SYDJournal is implemented in both /System/Library/PrivateFrameworks/SyncedDefaults.framework/Versions/A/SyncedDefaults and /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd. One of the two will be used. Which one is undefined.
Oct 15 09:36:10 Michaels-iMac com.apple.xpc.launchd[1] (com.apple.TMHelperAgent.SetupOffer): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Oct 15 09:36:38 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:_AMMuxedDeviceDisconnected, mux-device:192
Oct 15 09:36:38 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:__thr_AMMuxedDeviceDisconnected, mux-device:192
Oct 15 09:36:38 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8ddf - Mux ID not found in mapping dictionary
Oct 15 09:36:38 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8ddf - Can’t handle disconnect with invalid ecid
Oct 15 09:37:06 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:_AMMuxedDeviceDisconnected, mux-device:193
Oct 15 09:37:06 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:__thr_AMMuxedDeviceDisconnected, mux-device:193
Oct 15 09:37:06 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8ddf - Mux ID not found in mapping dictionary
Oct 15 09:37:06 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8ddf - Can’t handle disconnect with invalid ecid
Oct 15 09:37:53 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:_AMMuxedDeviceDisconnected, mux-device:194
Oct 15 09:37:53 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:__thr_AMMuxedDeviceDisconnected, mux-device:194
Oct 15 09:37:53 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8ddf - Mux ID not found in mapping dictionary
Oct 15 09:37:53 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8ddf - Can’t handle disconnect with invalid ecid
Oct 15 09:38:28 Michaels-iMac syncdefaultsd[80756]: objc[80756]: Class SYDClient is implemented in both /System/Library/PrivateFrameworks/SyncedDefaults.framework/Versions/A/SyncedDefaults and /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd. One of the two will be used. Which one is undefined.
Oct 15 09:38:28 Michaels-iMac syncdefaultsd[80756]: objc[80756]: Class SYDJournal is implemented in both /System/Library/PrivateFrameworks/SyncedDefaults.framework/Versions/A/SyncedDefaults and /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd. One of the two will be used. Which one is undefined.
Oct 15 09:38:54 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:_AMMuxedDeviceDisconnected, mux-device:195
Oct 15 09:38:54 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:__thr_AMMuxedDeviceDisconnected, mux-device:195
Oct 15 09:38:54 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8ddf - Mux ID not found in mapping dictionary
Oct 15 09:38:54 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8ddf - Can’t handle disconnect with invalid ecid
Oct 15 09:40:49 Michaels-iMac syncdefaultsd[80772]: objc[80772]: Class SYDClient is implemented in both /System/Library/PrivateFrameworks/SyncedDefaults.framework/Versions/A/SyncedDefaults and /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd. One of the two will be used. Which one is undefined.
Oct 15 09:40:49 Michaels-iMac syncdefaultsd[80772]: objc[80772]: Class SYDJournal is implemented in both /System/Library/PrivateFrameworks/SyncedDefaults.framework/Versions/A/SyncedDefaults and /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd. One of the two will be used. Which one is undefined.
Oct 15 09:41:27 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:_AMMuxedDeviceDisconnected, mux-device:196
Oct 15 09:41:27 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:__thr_AMMuxedDeviceDisconnected, mux-device:196
Oct 15 09:41:27 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8ddf - Mux ID not found in mapping dictionary
Oct 15 09:41:27 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8ddf - Can’t handle disconnect with invalid ecid
Oct 15 09:42:15 Michaels-iMac RapidWeaver 8[80780]: objc[80780]: Class CLSUserDefaults is implemented in both /System/Library/PrivateFrameworks/ClassKit.framework/Versions/A/ClassKit (0x7fff95480bd0) and /private/var/folders/bg/9n9x4zd577lbmy4kt21p4vx80000gn/T/AppTranslocation/A7C3C5E8-0162-4B33-8279-91AFB51DD8FD/d/RapidWeaver 8-4.app/Contents/MacOS/RapidWeaver 8 (0x104a4afd0). One of the two will be used. Which one is undefined.
Oct 15 09:42:47 Michaels-iMac RapidWeaver 8[80780]: assertion failed: 19A583: libxpc.dylib + 86780 [2E9076CD-6C0E-38B6-8403-B2DDCE125FBF]: 0x89
Oct 15 09:42:55 Michaels-iMac syslogd[120]: ASL Sender Statistics
Oct 15 09:43:21 Michaels-iMac com.apple.xpc.launchd[1] (com.realmacsoftware.rapidweaver8.2424[80780]): Service exited due to SIGILL | sent by exc handler[80780]
Oct 15 09:43:21 Michaels-iMac com.apple.xpc.launchd[1] (com.apple.WebKit.WebContent.72F45418-EFE2-419B-92F9-9F4E5285090C[80790]): Service exited with abnormal code: 1
Oct 15 09:43:33 Michaels-iMac Problem Reporter[80793]: assertion failed: 19A583: libxpc.dylib + 86780 [2E9076CD-6C0E-38B6-8403-B2DDCE125FBF]: 0x89
Oct 15 09:43:56 Michaels-iMac CoreSpotlightService[80818]: BUG in libdispatch: 19A583 - 1775 - 0x1
Oct 15 09:44:29 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:_AMMuxedDeviceDisconnected, mux-device:197
Oct 15 09:44:29 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:__thr_AMMuxedDeviceDisconnected, mux-device:197
Oct 15 09:44:29 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8de3 - Mux ID not found in mapping dictionary
Oct 15 09:44:29 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8de3 - Can’t handle disconnect with invalid ecid
Oct 15 09:44:29 Michaels-iMac diagnosticd[80823]: Posting empty stream filter
Oct 15 09:44:29 Michaels-iMac diagnosticd[80823]: allowing Console (80819) access to stream due to admin status
Oct 15 09:44:29 Michaels-iMac diagnosticd[80823]: Posting stream filter: “{
global = 47245099008;
Oct 15 09:44:29 Michaels-iMac diagnosticd[80823]: no EOS device present
Oct 15 09:44:29 Michaels-iMac diagnosticd[80823]: System mode client started - Console (80819) - mode: 0xb, filter: “”
Oct 15 09:44:35 Michaels-iMac syncdefaultsd[80824]: objc[80824]: Class SYDClient is implemented in both /System/Library/PrivateFrameworks/SyncedDefaults.framework/Versions/A/SyncedDefaults and /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd. One of the two will be used. Which one is undefined.
Oct 15 09:44:35 Michaels-iMac syncdefaultsd[80824]: objc[80824]: Class SYDJournal is implemented in both /System/Library/PrivateFrameworks/SyncedDefaults.framework/Versions/A/SyncedDefaults and /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd. One of the two will be used. Which one is undefined.
Oct 15 09:46:11 Michaels-iMac com.apple.xpc.launchd[1] (com.myheritage.familytreebuilder.checkupdates[80855]): Service exited with abnormal code: 1
Oct 15 09:46:59 Michaels-iMac com.apple.xpc.launchd[1] (com.avast.hub.schedule[80906]): Service exited with abnormal code: 11
Oct 15 09:47:52 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:_AMMuxedDeviceDisconnected, mux-device:198
Oct 15 09:47:52 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:__thr_AMMuxedDeviceDisconnected, mux-device:198
Oct 15 09:47:52 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8e2b - Mux ID not found in mapping dictionary
Oct 15 09:47:52 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8e2b - Can’t handle disconnect with invalid ecid
Oct 15 09:48:28 Michaels-iMac syncdefaultsd[81053]: objc[81053]: Class SYDClient is implemented in both /System/Library/PrivateFrameworks/SyncedDefaults.framework/Versions/A/SyncedDefaults and /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd. One of the two will be used. Which one is undefined.
Oct 15 09:48:28 Michaels-iMac syncdefaultsd[81053]: objc[81053]: Class SYDJournal is implemented in both /System/Library/PrivateFrameworks/SyncedDefaults.framework/Versions/A/SyncedDefaults and /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd. One of the two will be used. Which one is undefined.
Oct 15 09:48:56 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:_AMMuxedDeviceDisconnected, mux-device:199
Oct 15 09:48:56 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:__thr_AMMuxedDeviceDisconnected, mux-device:199
Oct 15 09:48:56 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8e2b - Mux ID not found in mapping dictionary
Oct 15 09:48:56 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:8e2b - Can’t handle disconnect with invalid ecid
Oct 15 09:49:31 Michaels-iMac com.apple.xpc.launchd[1] (com.apple.AddressBook.abd): Service only ran for 8 seconds. Pushing respawn out by 2 seconds.
Oct 15 09:51:29 Michaels-iMac Console[80819]: BUG in libdispatch client: vnode, monitored resource vanished before the source cancel handler was invoked { 0x600000782b00[source], ident: 15 / 0xf, handler: 0x7fff4d6d65c3 }
Oct 15 09:51:49 Michaels-iMac syncdefaultsd[81090]: objc[81090]: Class SYDClient is implemented in both /System/Library/PrivateFrameworks/SyncedDefaults.framework/Versions/A/SyncedDefaults and /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd. One of the two will be used. Which one is undefined.
Oct 15 09:51:49 Michaels-iMac syncdefaultsd[81090]: objc[81090]: Class SYDJournal is implemented in both /System/Library/PrivateFrameworks/SyncedDefaults.framework/Versions/A/SyncedDefaults and /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd. One of the two will be used. Which one is undefined.
Oct 15 09:52:04 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:_AMMuxedDeviceDisconnected, mux-device:200
Oct 15 09:52:04 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:__thr_AMMuxedDeviceDisconnected, mux-device:200
Oct 15 09:52:04 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:6407 - Mux ID not found in mapping dictionary
Oct 15 09:52:04 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:6407 - Can’t handle disconnect with invalid ecid
Oct 15 09:52:56 Michaels-iMac syslogd[120]: ASL Sender Statistics
Oct 15 09:54:26 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:_AMMuxedDeviceDisconnected, mux-device:201
Oct 15 09:54:26 Michaels-iMac AMPDeviceDiscoveryAgent[534]: Entered:__thr_AMMuxedDeviceDisconnected, mux-device:201
Oct 15 09:54:26 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:6407 - Mux ID not found in mapping dictionary
Oct 15 09:54:26 Michaels-iMac AMPDeviceDiscoveryAgent[534]: tid:6407 - Can’t handle disconnect with invalid ecid
@Mikehub Hey Mike, can you tell me where specifically you’re dragging an image to in RapidWeaver? Maybe take a screenshot and draw a box around the area to which you’re dragging.
Also, would you be able to send me the image that’s causing the crash?
Cheers
