I know there are lots of .htaccess posts about redirecting, but I just want to confirm my approach before I go any further.
I am helping someone do a re-branding of their business and am moving their redesigned site to a new URL. They’re with GoDaddy and GoDaddy has a simple domain forwarding option in their domain settings. Things are generally working as expected, however, I think the old site has an expired SSL and there are some google search links that have ‘https’ in the address and when you click those, the redirect isn’t kicking in. Change the ‘https’ to ‘http’ ion the URL and it redirects fine.
So, I guess my questions are:
I am presuming that I should remove the ‘forwarding’ settings and do things via htaccess?
If so, would I force http first, then redirect to the new domain?
If that is also correct, this is the code I have for forcing http:
RewriteEngine On
RewriteCond %{HTTP_HOST} ^example.com$ [NC]
RewriteRule ^(.*)$ http://www.example.com/$1 [R=301,L] -
And then this is what I have for the redirect (I want all sub files/folders to just go to the main domain, I don’t need to match any files/folders)
RewriteEngine On
RewriteRule ^(.*)$ http://newdomain.com/ [R=301]
Do I have (any of) that correct? Is the order of the redirect important?
