Removing tags in blog
Hello
I am using Voyager Pro and RapidWeaver 7. Here I have a blog with historical documents. In the tags I register every person found in the actual document. In some documents this is very many.
A blog entry consist of the full document and a short version. Under the short version of the document all tags from the actual documents are listed. The result is that you can not see the next short entry.
I want to make these invisible or remove them. I want to keep them in the sidebar, but not under the short version of the blog entry.
Bjørn Arve
To “remove”, add in Rapidweaver > Inspector > HTML (Code) > CSS:
.blog-entry-tags {
display: none;
Or to hide (keeps the reserved space), use:
.blog-entry-tags {
visibility: hidden;
Hi Ikemitsu
I have forgot to tell that your solution worked perfect for me. Very rude of me, but better late than never I hope. Thanks a lot.
Bjørn Arve
