Resources crash and odd behaviour
I had a hard crash trying to drag some resources from one project to another. I’m not sure if it’s meant to work but it doesn’t appear to (report sent).
Also, at one stage adding resources from the finder I had a major slow down and eventually had to force quit. I’ve also had a hard crash doing this.
When there’s a folder inside the resources area, items dropped into resources often end up in the folder even though they weren’t dropped onto it.
This is fairly trivial, but if you quicklook an item in Resources then arrow up or down, the quicklook doesn’t display the newly selected image. You have to close the quicklook and then open it again to get the new image.
