Retina images with the Foundation Orbit slider
I am using the Foundation orbit slider for a Header with sliding images. Now i want these image show in the original format as used in the Stack. But after uploading they are all downgraded to 1200x398. When somebody on a Retina screen these lower resolution is show and that does not look good. Anybody know a trick to solve this?
Are you using the Foundation Image stack or the Image stack that comes with the Stacks plugin?
@zeebe , You hit the right button :slight_smile: I did indeed use the normal image stack. I replaced it with the one from Foundation… all alright and solved now. thx!
